Aftermarket or stock?
Old Feb 15, 2016 | 06:59 AM
Chevyss909's Avatar
Default Aftermarket or stock?
So i was wondering if i need a aftermarket fuel pump or can i use the stock one with my mods
2007 classic 6.0 228/232 243 heads 232cc advanced induction port job
Tbss intake 8.1 marine injectors
And so on lol i made 402 hp on 2nd gear pull due to stock driveshaft
Will my stock fuel pump be sufficient or should I consider a aftermarket one
Any info is greatly appreciated guys
Old Feb 15, 2016 | 08:41 AM
Atomic's Avatar
I have a gauge for that
If you have the flex fuel system you will be fine up to 500 or so.
Old Feb 15, 2016 | 12:10 PM
Chevyss909's Avatar
No flex fuel how much hp are stock pumps able to hold?
Old Feb 15, 2016 | 12:16 PM
Atomic's Avatar
Not much...350 on a good day.
Old Feb 15, 2016 | 12:33 PM
Chevyss909's Avatar
Right on
Any thought on any good aftermarket ones?
Old Feb 15, 2016 | 01:52 PM
Atomic's Avatar
If you dont plan on boost a walbro 255 would put you at 550ish and a walbro 400 would put you at 700ish.
Old Feb 15, 2016 | 02:39 PM
Chevyss909's Avatar
Cool thanks for ur knowledge my man
Old Feb 15, 2016 | 03:33 PM
Atomic's Avatar
Your injectors would max out at probably 400 though...
Old Feb 15, 2016 | 03:50 PM
Chevyss909's Avatar
When i got it tuned he said i was no where near maxing out the 42lbs
Old Feb 15, 2016 | 04:03 PM
Atomic's Avatar
Yea, I was a little off just shooting from the hip.
42lb@4bar injectors will do roughly 475rwhp at 60psi at 95% IDC.
At 60psi NA,
Walbro 255 will support ~530rwhp
Walbro 400 will support ~800rwhp
Walbro 450 will support ~900rwhp
Check out the stickied thread in the top of the fuel section for a spreadsheet I made that does all this.
