After market fuel rails for stock intake
Old Feb 9, 2016 | 06:49 PM
TAPyvehc93's Avatar
Default After market fuel rails for stock intake
Does anybody make some aftermarket fuel rails for the NNBS intakes?
Edit: If anyone is curious, I was able to get some aftermarket fuel rails on my NNBS intake. I used the new Holley LS1/LS2/LS3 rails that have the different mounting holes on the bottom instead of the side holes. Due to the compound angle of the injectors, It wants to push the fuel rail into the pedestals on the intake thus not letting the injectors sit at the proper angle. What I ended up doing was end milling the pedestals down .200 and it ended up working out perfectly for me. The injectors now sit perfectly. Then, all I did was buy some flat piece of 1/8" steel to make my brackets and BAM, all done. Now to just decide on a fitting to clear the ALT....Oh by the way, I'm also using injector height adapters.
Old Feb 10, 2016 | 07:38 AM
!Hostile!'s Avatar
Somewhere on this forum. I believe its in the projects gallery....a guy is running a set of Nasty Nates fuel rails. Google those three words you should see them.
Old Feb 10, 2016 | 08:47 AM
George C....'s Avatar
Formerly ScreamingL
Grab any set of rails and make your own adapters
Old Feb 12, 2016 | 09:12 PM
TAPyvehc93's Avatar
Well my holley rails off my hi-ram have a different injector angle then the stock intake....
Old Feb 12, 2016 | 09:22 PM
Formerly ScreamingL
Shouldnt have a different angle...ive saw holley raims on stock intakes before
Old Apr 27, 2016 | 08:06 AM
TAPyvehc93's Avatar
Old Apr 27, 2016 | 10:24 AM
LongBlue's Avatar
Originally Posted by TAPyvehc93
Fore Innovations makes a billet 90 that threads directly into the fuel rail. I have the same Holley rails and with the billet fitting have no clearance issues.
Wolftrk99
Oct 5, 2022 05:27 PM
TAPyvehc93
Mar 10, 2016 08:35 PM
dr_whigham
Feb 14, 2016 12:05 PM
dantheman1540
18
Feb 7, 2016 10:04 PM
