Aeromotive 340
Old Sep 10, 2012 | 04:55 PM
TIM Z's Avatar
11 sec. Truck Mod
Default Aeromotive 340
I've read that there are possible problems with the aeromotive 340 pump, anyone care to elaborate ? I've heard nothing but have one in my tank . Should I be concerned?
Old Sep 10, 2012 | 05:39 PM
milkey57's Avatar
My pump was my secondary on a hobbs switch, it lasted an amazing 8 months b4 it crapped out. A walbro now sits in its place working great. I have read of a few other guys with similar issues with them taking a **** in a short period of time. I would keep a backup at home just in case.
Old Sep 10, 2012 | 05:41 PM
TIM Z's Avatar
11 sec. Truck Mod
That sucks , damn . They aren't cheap either .
Old Sep 10, 2012 | 05:52 PM
xChris's Avatar
A friends truck switched his pump and now the truck wont crank!
Im not blaming the pump but the truck is useless right now, he has tried almost everything possible
https://www.performancetrucks.net/fo...-crank-507462/
Old Sep 10, 2012 | 06:40 PM
chevyboy.520's Avatar
I had mine for less then 5 months. It was cooler out when I dropped it in. Then it started to get hot out. And my problem started. It would seem to vapor lock. The pump would get so hot that I would just shut down! I wouldnt trust one even as a second pump on a Hobbs. I found walbro 400 cheaper then the aero 340.
I recently switched from return less to return style. Added a aero regulator. First I had just the aero 340 in the tank. And my problem still happened. Pump over heated. I dropped in a walbro 255 and have had no problems.
With the aero 340 I would watch fuel pressure drop to 40-45 psi while on 10psi
When I switched to the walbro 400 I would see fuel pressure drop to 50 psi while on 12psi.
For anyone thinking about a aero 340 I would highly recommend not getting it. Buy a walbro 400 and if your on E85 they have a walbro set up for E85.
Old Sep 10, 2012 | 08:19 PM
TIM Z's Avatar
11 sec. Truck Mod
Thankyou for sharing that info , appreciate it.
Do you have a Hotwire kit? Just wonder if that was part of your issue?
Old Sep 10, 2012 | 08:49 PM
03sierraslt's Avatar
Dont let your fuel level get low Tim.
Old Sep 10, 2012 | 09:31 PM
gavin2005's Avatar
mine just went out the other day.it lasted about 5-6 months with less than 1k miles on them(i have dual intank)i called jegs yesterday and they told me to ship them back and they will refund my money.
Old Sep 10, 2012 | 09:59 PM
ltr450ryder's Avatar
u have a link for this pump with the e85 setup?
i have a 340 now in my truck on have about 4-600 miles on it but i would like to have the walbro 400 as a back up thanks
Old Sep 11, 2012 | 04:13 AM
TIM Z's Avatar
11 sec. Truck Mod
I never go below qtr tank just for safety and my own piece of mind.
