Accel 62lbs injectors
Old Jun 19, 2012 | 08:01 PM
stoicho315's Avatar
Default Accel 62lbs injectors
I purchased the accel 62lbs injectors off of Jegs which summit has the same ones witht the same part number, i received them i thought they looked a bit off, i called jegs and was assured the were plug and play, after finally starting the tear down on my truck i noticed the plug was way off,i called jegs and was told there was an adapter kit for 44 dollars, i removed the original injector and it was about a half inch longer then the accel, the website says they will fit the truck with a factory set up, needles to say they wont, i myself should of done more research, the Jegs tech guy and myself felt Accel was delusional, and they wont fit, Just throwin this out there if anybody runs across these
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
