82 PSI!!!!!! Can't be good???
Old Jul 16, 2013 | 01:15 AM
Fastcount03's Avatar
Default 82 PSI!!!!!! Can't be good???
So I checked my fuel pressure and KOEO it's right at 62 psi, but running it goes up to 82 psi! My setup is on an 03 silverado with return style system. I have an aeromotive 340 pump, stock lines into a vette filter feeding the square NNBS rails on a L92 intake with LS3 injectors. Why would my pressure be so high and what could this cause/hurt and how do I fix it? Do I need to go ahead and replace my lines, FPR, and do some aftermarket rails? I was thinking of doing that anyway with a new holley midrise intake.
Old Jul 16, 2013 | 01:36 AM
Also the leakdown was fast! It went down to 20 psi in less than 2 minutes... where would you guys look first? Vette filter? in the tank, or bad injector(s)?
Old Jul 16, 2013 | 03:26 PM
Anybody?? or is this a really dumb question?
Old Jul 16, 2013 | 03:45 PM
brent1976's Avatar
11 Second Club
Did you ever get your kinked fuel lines figured out?
Old Jul 16, 2013 | 04:17 PM
Atomic's Avatar
I have a gauge for that
What does it do with the vacuum reference for the regulator disconnected? Truck run rich?
Old Jul 16, 2013 | 04:22 PM
Brent, no I have them in a happy medium I'm guessing... they are still some what kinked and could be the problem with the return kinked off...
Atomic, I don't have the stock regulator. I'm using a corvette filter in it's place.
Old Jul 16, 2013 | 04:55 PM
Atomic's Avatar
Does the vette filter not have a vacuum reference?
Old Jul 16, 2013 | 05:40 PM
George C....'s Avatar
Formerly ScreamingL
which brand vette filter?
wix or GM all others are cheap and will send Fuel PSI thru the roof
Old Jul 17, 2013 | 12:08 AM
It's a WIX brand filter. No Atomic, it is internally regulated somehow, not really sure but it's not vacuum referenced.
Old Jul 17, 2013 | 01:14 AM
oakley6575's Avatar
So your return line is kinked and you are having high pressure issues... Why haven't you fixed the lines?
