1/2" rail spacers not enough for Siemens deka?
Old May 22, 2017 | 08:08 AM
turbo_outlaw's Avatar
Question 1/2" rail spacers not enough for Siemens deka?
2006 4.8 non-flex
I removed the stock injectors and installed some Siemens deka 60s. From my research I know that 1/2" spacers and longer bolts are required so I purchased them prior to install. My problem is I don't think 1/2" spacers are enough, 3/4" might work though.
Has anyone else had this issue? I'm pretty confident the injectors are all the way down.
Old May 22, 2017 | 08:24 AM
03sierraslt's Avatar
I thought they required 5/8
Old May 22, 2017 | 08:32 AM
Initially I got the info from Sloppy Mechanics. All of the other "how to" pages and even kits I found use 1/2" fuel rail spacers. I'm unsure
Old Jun 2, 2017 | 10:13 AM
GRRR65GTO's Avatar
When I put my 80 lb injectors in a used some brake line and longer bolts and cut it to roughly 5/8 like mentioned
Old Jun 4, 2017 | 04:47 PM
usafws6's Avatar
Tuner Lvl 0
I cut mine to about .6 and it was a tad short. .75 probably would've been spot on.
