Ford Parts Classifieds For Sale and Wanted
Winston Cup SVO block Winsdor 355ci
Old Oct 25, 2005 | 03:01 PM
Default Winston Cup SVO block Winsdor 355ci 630-800hp monster
4 bolt main splayed caps/ Currently set up for dry sump oil pan / can be changed to wet sump.
Lentz rods / Full floating rods / J&E pistons / 10:1 compression / Spiral Locks / Steele SVO crankshaft standard / Dry sump oil pan / 2 reid solid roller camshafts(to get specs PM) Solid roller lifters only 3 hours use / Hardened chromoly push rods / Crane 1.6 roller rocker arms / roller springs cap. of .800 lift / titanium retainers & locks / Valves are titanium & stainless / Clevend style Winston cup heads aluminum(not yates but jack roush) 50 hours of machine work on heads / bronze guides / poly-locks / studded mains / studded head bolts / Double roller SVO timing chain set / Aluminum water pump / billet pulley / single plane hi rise jack roush intake / SVO dampener internally balanced engine / chrome moroso valve covers / needs Clevend style headers / file fit rings.
Motor is apart now but can be put back together
Motor made 630 hp with 9:1 pistons an 390 cfm carb, it is capable of 800 hp
Locust Grove Ga. Will deliver within 75 miles or if buyer wants freight. $4000.00 firm PM for contact info
calsdad
Jun 14, 2023 11:07 PM
gmcyukon
Oct 5, 2015 06:20 AM
Mark_k
Oct 1, 2015 11:17 PM
old motorhead
Sep 29, 2015 08:22 PM
trevorh1
Sep 27, 2015 08:47 PM
