Ford Engine & Exhaust Performance All EFI, 4.6, 5.4 Triton
what muffler should I run??
Old May 18, 2010 | 09:46 PM
Chansen's Avatar
Registered User
wish that was the case. I use the cruse controll as much as possible expecally when traveling, My speed fluchates way to much if not..
Old May 18, 2010 | 11:26 PM
Chansen's Avatar
Registered User
Originally Posted by honeycutt.dewey
if they're broken or plugged up, absolutely i've never experienced a situation where low back-pressure caused you to lose gas mileage. how's it running? any misfires? vibration, etc?
seems to be running fine. No misfires or vibrations that I have noticed. How do you check to see if your cat is plugged up?
Old May 18, 2010 | 11:32 PM
Dewey's Avatar
unfortunately, the only way to see if they're broken is to check for codes or cut them off and look... if they're broken, you can take a rubber mallet and tap the outside casing very lightly. you'll hear a distinct rattle if the catalyst is shattered.
Old May 20, 2010 | 04:12 AM
stoffer's Avatar
I paid my buck-o-five
these triton motors are partial to back pressure, you have to leave the exhaust 2.5 inch diameter if you run true duals (until you get over 600rwhp) or a 3 inch single
Old May 20, 2010 | 06:10 PM
Chansen's Avatar
Registered User
I am pretty sure that it is 3" all the way back. I didn't change any of that just had the muffler shop put a high flow muffler on it to open it up a little more. Should I go back to the stock?
Old May 23, 2010 | 07:31 PM
Chansen's Avatar
Registered User
I think that I got it figured out.. i ran Premium gas in it all weekend and the tank that I ran home on didn't have any ethonal in it. Got 15.46 MPG...Think that that maybe the Problem...Hopefully
stealthperf
34
Feb 14, 2016 11:35 AM
Wareagle23
Aug 8, 2015 10:06 AM
Zack R
Aug 3, 2015 06:02 PM
askkmb
Jul 18, 2015 09:02 PM
kdw8888
Jul 9, 2015 10:52 PM
