Ford Engine & Exhaust Performance All EFI, 4.6, 5.4 Triton
Anybody know how to do a tune-up on 2003 F-150 4.6?
Old Apr 18, 2008 | 06:28 AM
14 Second Truck Club
Default Anybody know how to do a tune-up on 2003 F-150 4.6?
Need to change the plugs, spark plugs, & coilpacks on a 2003 F-150 4.6. The damn fuel rails are over everything. Anybody ever done this? I'm just gonna jump in and see what I can do, but I was wanting to know if there was any easy how-to's or don't do's. Thanks.
Old Apr 18, 2008 | 07:59 AM
truckmann's Avatar
Best way to do a tune up on a Ford---->>>Sell it and get a Chevy
I don't know. I heard those modulars (if that is what this one is) are a bastard to work on supposedly it's like a 3 hour job to change the plugs for someone that knows what they are doing.
Good Luck!
Old Apr 18, 2008 | 11:43 AM
203Cree's Avatar
For someone that knows what they're doing, it's abouta 45 min job on plugs. First timer, plan on a couple hours. Easiest thing you can do is pull the fuel rails loose.
Old Apr 19, 2008 | 02:46 AM
Thanks for the info! Do I need to loosen and pull up the injectors, while leaving them attached to the rails?
Old Apr 21, 2008 | 10:54 PM
fordbug77's Avatar
if you have a good wobble socket 7mm, you can do it without having
to mess with the fuel rail. The hardest one is #5,
Take your time and do one at a time, remove the coil. then remove the
plug replace it and go on to the next.
Good luck.
Old Jun 1, 2008 | 08:08 PM
willcarsrule's Avatar
Registered User
well on the expeditions with rear ac #4 is the hardest #5 is easy and who takes the fuel rails out? 7mm wobble and u get the cop's out with no problem (#7 has the fuel reg. next to get u push the injector towards the rear and if u need unplug the injector to gain access). I have done like 10 5.4L and 6 4.6L tune ups not to mention all the cop's replacements i have done. with an 1/4 air ratchet u should be able to knock them out in 45mins.
calsdad
Jun 14, 2023 11:07 PM
SloSVO
Nov 22, 2020 07:34 PM
twake_410
Apr 14, 2016 09:58 PM
FlowmasterMufflers
Nov 24, 2015 01:00 PM
6.0l RST
Nov 23, 2015 11:30 AM
