Z71 4wd turbo plan for DD and towing (and FUN!)
Old Jul 2, 2012 | 01:10 PM
  #21
coletrain777's Avatar
So since my truck is lifted 9 inches on 35" tires I would imagine I have tons of room to build a lowmount, frontmount turbo... correct? Is there any reason that I shouldn't do that? I don't do any mudding or 4 wheeling other than getting up my driveway or driving across a field.
Old Jul 3, 2012 | 09:30 AM
  #22
nonnieselman's Avatar
Theres a good bit of room up front for a turbo.
also for a factory Turbo look at the Holset HX35 of the 5.9L 12V cummins. I think they are good for about 6-8psi on a 4.8 or 5.3, and 8.1 Marine injectors are 44# so that should get you by for your goals.
I use to mud ride with my remote mount. just had to make a sheild for the filter and it worked. id have to clean the filter afterwards tho
If you do a rear mount, you can run the filter over and up between the fender well where the outside bed skin and the iner part have a gap. keeps the filter clean and out of the crud.
Old Jul 3, 2012 | 09:33 AM
  #23
Oobray
Jun 13, 2022 03:38 AM
vmaxpro
Jul 27, 2015 10:45 PM
Suburban2500
Jul 19, 2015 04:50 PM
4B11T
Jul 13, 2015 03:48 PM
Aboss
Jul 9, 2015 10:28 AM
