Z06 cam is in boost?
The Z06 cam is in and running. I did a couple of pulls this evening and noticed that my boost is down a little. I am down about 1psi on the low boost and high boost settings. Have any of you guys had the same experience or am I just weird. I am wondering if this cam bleeds of a little boost or if I have a little leak somewhere. When I am on high boost it spikes to about 8.5-9psi and then settles down to 7psi through out the run. Before it would settle at 8psi where I had it set. It still feels quite a bit stronger even with the lost boost.
I don't completely understand your answer. Shouldn't my wastegate keep me at the same boost level no matter what cam I have in it.
I only drove it for about ten minutes but it felt pretty good with the 2600 stall. I does feel like it spools up a little slower but I haven't wrapped my pipes yet so that will help. I am going to work on my tune tomorrow so I will see how part throttle feels.
. Did you notice any changes in drivability or off boost response?
