Yep, another radix/pulley post...
Old Oct 23, 2006 | 12:48 PM
  #31
moregrip's Avatar
what a rush!
Originally Posted by m7 rocket
Okay, I got conformation of 3.2" pulley and 112" belt is what I was sent.
good deal, I believe magnuson uses the 2.8 pulley for high altitude applications, but I think a 2.9 or 3.0 will do you just fine.
Old Oct 23, 2006 | 01:54 PM
  #32
Allgonoshow's Avatar
Now that you know what you have, get yourself some boost.
My little 5.3 makes 8psi at wot and works real GGOOOODD.
Tows my 5000 lb boat pretty good too, smoking ricers with a trailer in tow on a big hill is too funny.
Old Oct 23, 2006 | 08:55 PM
  #33
m7 rocket's Avatar
I know what ya mean. I already have a good advantage, even with the 16,500 GCWR I weigh in at, and only 4.5 PSI. Can hardly wait. Just need to verify the tuning is not necessary with Campbells. He has said no once, but I don't like the pistons outside my block. maybe I will invest in a wideband and put that and my new Aeroforce in a 2 pillar mount or something.
Old Oct 24, 2006 | 06:13 AM
  #34
i got one of these from Carquest, $325cdn ,
http://www.ngk.com/afx/
works good, easy install, big numbers so it's easy to read when driving . I put it in the small storage slot to the left of my cluster but your 4x4 switches might be there. there is another slot below the airbag switch that it might fit in as well.
Old Oct 24, 2006 | 06:34 AM
  #35
m7 rocket's Avatar
Thanks Allgo. I do need to find a air/fuel gauge. I would prefer one that has a large digital readout like that, but in a 2 1/16" round gauge, black face with silver or grey bezel. Any ideas anyone. Autometers just use the narrow band, what a POS.
Hey I just read this on that link
"Analog Compatible
The NGK AFX has a 0 ~ 5V, linear analog output for AFR that can be used as an input to an engine controller, data acquisition system, or analog gauge with 0 to 5 volt input. "
I wonder if I can just buy a wideband O2 sensor and hook it to my Aeroforce gauge. May need to supply a 0-5 V but I think I can find that somewhere. Any ideas?
Just when I thought I was done spending... <--wife
Old Oct 24, 2006 | 11:08 AM
  #36
how about this one....
http://www.aempower.com/ViewCategory.aspx?CategoryID=70
Old Oct 24, 2006 | 05:25 PM
  #37
m7 rocket's Avatar
You must sit in front of your PC all day at work! That is exactly what I am looking for. Now to try and find in Canada. Cheers
Old Oct 24, 2006 | 06:18 PM
  #38
m7 rocket's Avatar
Actually, I read a little closer and you need a laptop with that one. What you need is this one... Of course more $$$, dammit. And I had my hopes up.
http://www.aempower.com/ViewCategory.aspx?CategoryID=67
Old Oct 24, 2006 | 06:31 PM
  #39
any speed shop can order that , aem is big on ricer stuff too
I think carquest could get it too but was pricey, i forget.
carquest stores order hotrod stuff thru keystone if your local store doesn't know.
might still be cheaper on ebay
http://motors.search.ebay.com/30-410...itleZ30Q2d4100
no, not on my pc all day, i 've just looked for the same stuff myself and bookmark it.
if i sent you my favorites for truck stuff you would need a new hard drive
extendocab
Aug 23, 2006 09:40 PM
alan2000T/A
23
Aug 11, 2006 06:54 AM
bluecajun5.3
Jun 8, 2006 12:07 PM
