Yep, another radix/pulley post...
Originally Posted by moregrip
lol! no kidding huh
.............the other thing is tuning, you'll need some
.............the other thing is tuning, you'll need someI guess I don't need tuning. I asked the guy that tuned it and he said go hard. Unless getting 10 PSI it will be fine. He said if I want to he can re-do it, but not necessary. 2 bar MAP table is ready to go. Over my head from there.
is this because he has already done a radix'ed truck JUST like your with2 bar? Are you still using the maf with your 2 bar or are you really without it?
Originally Posted by dewmanshu
i thought you had a 3.4 or a bigger than radix stock pulley? hmmm.
yeh, .3 will get you a lot. But it will also make for hotter and quicker rise IAT temps. Bare that in mind. Belt size on a stock setup with 2.9, uhhhh say 111.5 down to a 111.0. At my elevation I went from a 3.0 pulley to a 2.8 pulley. My boost went from 7.5ish to 8.7ish. In the real cold weather I can squeak 9.2#'s. Not sure of HP quotes. It ranges with different systems. moregrip is probably real damn close with the hp quote.
I am hoping with my larger intercooler exchanger and rad that the temps will be okay, since I really only want what a "non-towing" kit would put out. Okay maybe 1 more PSI. Okay maybe 2... but that is it. 3??
I think the non towing is 7 PSI right?
I dunno what the hell I was told from Maggie on the "towing kit/pulley size" I get a different story from everyone I talk to. Botom line I guess is that I have 4.5 PSI, always have, and a 3.2" pulley on pretty stock LQ4. Maybe I should measure crank pulley, I did by truck used. Anyone remember stock OD?
non towing is whatever pulley it takes to get 6-7 lbs of boost.
stock crank OD is 7.5", however it's not readily apparant by measuring
at the very least, take some logs
measure the outside diameter of the pulley(blower). Post it up. Grip or blownchevy will set you straight. I can't imagine you have a 3.2. With 4.5psi? But I am no good at the elevation thing either. so..measure and post.
is this because he has already done a radix'ed truck JUST like your with2 bar? Are you still using the maf with your 2 bar or are you really without it?Yes my MAF is not being used.
