Would setting up twins like this change the performance in any way?
Old Jul 15, 2012 | 10:33 PM
Three6GMC's Avatar
Default Would setting up twins like this change the performance in any way?
I was thinking both turbos into a intercooler and into the tb. Plain and simple. But then I stumbled across this pic of a Hennessy twin turbo Escalade. Looks to be like almost a compound setup. The Passenger side turbo is boosting into the driver side turbo and then into an intercooler and into the engine. Would running them this way change or better performance? I would think it would be the same thing but thought I would ask. Hennessy is def making some good power with them like this so don't think its hurting anything performance wise.
Old Jul 15, 2012 | 11:39 PM
Atomic's Avatar
I have a gauge for that
It really depends what you are going for...that is a sequential twin setup. What happens is you basically multiply the pressure ratios from each turbo to end up with the final engine pressure. It is much more common on diesels that run 40+ psi all day than on gas engines because a single turbo (or a twin parallel) setup will be fine at whatever pressure ratio you want on a gas engine.
A setup like this can be tweaked A LOT by playing with the wastegates of each turbo and by the size of turbo...typically you have a larger turbo feeding a smaller one, but this looks like two of the same size meaning you can have a lot of pressure, but somewhat limited mass flow...
Old Jul 16, 2012 | 12:09 AM
Llaverito's Avatar
I see two air filters i dont think the passanger is feeding the driver.
Old Jul 16, 2012 | 12:26 AM
Three6GMC's Avatar
That's true didn't notice that lol. Bet that pipe just runs across just to put the driver side filter over there. Damn I feel kinda dumb now haha
Old Jul 16, 2012 | 12:38 AM
Atomic's Avatar
My response still applies to sequential setups
Steve-O-08
Apr 19, 2018 09:32 AM
cbhedrick
Jul 20, 2015 10:12 PM
black6spdz
Jul 16, 2015 01:32 AM
01sierraon22s
Jul 8, 2015 11:26 AM
