Worth it??? Used D-1SC...
Old Dec 14, 2009 | 04:10 PM
02'Z71ONDUBZ''s Avatar
Default Worth it??? Used D-1SC...
I found a guy willing to sell me a D-1SC for $250. He sucked something through it, messing up the impeller. Called ProCharger today, and all they would tell me is that they had an $85 analysis fee for tearing it down, and that they wouldn't be able to give me an estimate until then. They did tell me that a new impeller would cost around $900. Any ideas on what bearings and seals will cost, along with labor? I figure that will put me around $1200, and if I can get everything else done and keep it around $1500 and have a rebuilt blower I will be in good shape. Any thoughts???
Old Dec 14, 2009 | 04:13 PM
Mangled03gmc's Avatar
Baltimore Whore
They are going to hit you for atleast a grand.. But if you can part it together for under 2k you got a winner... Is that with the brackets for the unit also??? Pass the deal on to me ..
Old Dec 14, 2009 | 06:10 PM
No brackets or pulley... I already have the brackets and hardware for my truck; it's for a P1, but their both the same as far as mounting from what I can see. I hadn't planned on going with a D1 until I found this deal; also hadn't planned on spending 2k on a blower. I was intending on spending closer to 1k on a P1, going the cheaper route.
I'm thinking it will be worth the extra $500-$1000 to get a rebuilt D-1 over over a used working P-1 now though...
Old Dec 14, 2009 | 08:52 PM
sureshot's Avatar
Yes, the P1 and the D1 are the same exept for the impeller, so if your bracket works for a P1 it should work for a D1. If the price is right, go D1.
Old Dec 14, 2009 | 09:39 PM
What's a ballpark figure on what a good used P1 and also D1 are worth$$$?
Old Dec 15, 2009 | 04:43 AM
Most Hated's Avatar
but then u can make ur p1 a d1 for 1200 + s&h
Old Dec 15, 2009 | 06:11 AM
hemidup's Avatar
I just sent in a P1 for the D1 upgrade. They charged me waaay more than that.
Old Dec 15, 2009 | 07:58 AM
Rick_Vor's Avatar
The 2009 Procharger catalog lists a P-1SC to D-1SC conversion at $1327 so $1500 is probably in the right ballpark after it's all said and done.
Rick
Old Dec 15, 2009 | 10:41 AM
idahoblkss's Avatar
what did they charge you??
Old Dec 15, 2009 | 06:05 PM
Well after some research I have concluded that procharger breaks it off in the a$$es of each person that sends in a unit for a rebuild. First off, the bearings used on the high-speed side of the blowers appear to be rated at I believe 51K, yet ProCharger rates their blowers at 62K. They told me it would cost around $900 for a D-1 impeller, yet you can buy quality used ones online for $295( http://www.superchargerrebuild.com/?page_id=53 ). Also, note that all used impellers are the same price, P600B or D-1SC.
Procharger uses a custom seal for the back shaft that you cannot seem to buy or find from seal mfgr's. You have to have them custom made, which is what superchargerrebuild.com must do to complete their kits. My question is, has anyone purchased a seal/bearing rebuild kit from this website, and if so what did you think of the quality?
They will completely rebuild your blower for $550, replacing all bearings as well as seals. The parts are sold for $350, if you wanted to do it yourself. The $200 labor fee for a complete rebuild sounds a little more reasonable to me than the alternative... considering ProCharger wants $85 just to look at it. They are ridiculous....
