Worth header change ?
I have tri y 1 5-8 going to 2 1/2 y then 3 inch muffler on my 2010 5.3.
I have tvs 1900 and stepping it up to 8.5 to 9 psi from 5.5 and adding a eps cam.
What am I losing rwhp wise ? Thinking 1 7/8 headers to true duals 3" mufflers
Thx guys
Thx guys
What cam are you running? How high are you revving the setup?
IMHO, unless it's a pretty radical setup, you don't need 1 7/8" headers for most 8-9 psi 5.3's.
Now, if you're maxing out the 5.3 with 14-15 psi, and heads & cam etc, and shooting for 600+ rwhp, then you will be better off with the bigger headers & exhaust.
No doubt better flowing exhaust will help.
I read an article where they tried a few different engine/blower combos and changing exhaust. On the N/A set up, the difference in power was substantial. I think like 80-100hp. On the blown engine, it was like 10hp. I think the combo made 500hp NA and 1000 with blower.
Not the original article but one along the same lines.
http://www.kennebell.net/KBWebsite/Common/pdfs/header_cat_xpipe_exhaust_tests.pdf
Noah Burns
Sep 7, 2015 05:50 PM
sauldgold
Jul 23, 2015 02:15 PM
