Worth header change ?
Old Dec 6, 2014 | 07:25 PM
Matt331's Avatar
Default Worth header change ?
I have tri y 1 5-8 going to 2 1/2 y then 3 inch muffler on my 2010 5.3.
I have tvs 1900 and stepping it up to 8.5 to 9 psi from 5.5 and adding a eps cam.
What am I losing rwhp wise ? Thinking 1 7/8 headers to true duals 3" mufflers
Thx guys
Old Dec 6, 2014 | 07:41 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
What cam are you running? How high are you revving the setup?
IMHO, unless it's a pretty radical setup, you don't need 1 7/8" headers for most 8-9 psi 5.3's.
Now, if you're maxing out the 5.3 with 14-15 psi, and heads & cam etc, and shooting for 600+ rwhp, then you will be better off with the bigger headers & exhaust.
Old Dec 7, 2014 | 12:42 AM
Blown06's Avatar
8 Second Truck Club
It is my opinion that you can never over exhaust a blown deal. How much will you gain..........who knows.
Old Dec 7, 2014 | 01:00 PM
lt1s10's Avatar
Originally Posted by Blown06
It is my opinion that you can NEVER over exhaust a blown deal. How much will you gain..........who knows.
...fixed.. You will prob drop a pound or two of boost but the power and efficiency will raise. The downside will be $ and noise.
Old Dec 7, 2014 | 11:17 PM
Blown06's Avatar
8 Second Truck Club
Thanks man. Yes that is what I meant to type.
Old Dec 9, 2014 | 06:36 PM
Last Call's Avatar
TOTM: January 2007
No doubt better flowing exhaust will help.
I read an article where they tried a few different engine/blower combos and changing exhaust. On the N/A set up, the difference in power was substantial. I think like 80-100hp. On the blown engine, it was like 10hp. I think the combo made 500hp NA and 1000 with blower.
Not the original article but one along the same lines.
http://www.kennebell.net/KBWebsite/Common/pdfs/header_cat_xpipe_exhaust_tests.pdf
Old Dec 11, 2014 | 05:22 PM
Matt331's Avatar
Thx for replies, mixed comments. Would modifying my ypipe to 3 inch and just true duals with 3 inch mufflers be a good idea. ?
Noah Burns
Sep 7, 2015 05:50 PM
Hmguyton
Aug 9, 2015 05:38 PM
steves86ta
Jul 28, 2015 10:21 AM
sauldgold
Jul 23, 2015 02:15 PM
Ketis
Jul 23, 2015 12:37 PM
