will pay 50$ for good advice
got a retune truck runs like a bat out of hell .now here the problem.cold start up truck will not
drop in to passing gears and will die within 1/8 mile at first stop sign from my house.it start up cut right back off(run for about 2seconds.if I leave ignition on and unplug ignition relay under hood and wait 30 second it start back up run fine .but still no passing gears.but once truck get around 18o degrees both problem got away.no codes use to throw code 121 and1635 but I replaces throttle position both code gone now .but still no passing gear trans mission changes fine .like I said 50$on stand by
If the converter is staying locked up, yea it would cause the engine to stall.... But I don't know what was changed in your tune. Need to look mainly at your shift settings... Then at your shift solenoids
4l80 e,stockthrottle body.shift manual fine. wait on truck to cool down .I may have found the problem .the fuse box under hood the ignition relay .the ground wire pin was push out from bottom side .will post back if this fix it
