Will my stock Tb work on lsa blower
Old Feb 29, 2016 | 12:03 PM
About20ninj45's Avatar
Default Will my stock Tb work on lsa blower
vehicle in question is a 06 yukon denali. Can i use my orignal Tb on the lsa blower? Will i need an xlink?...
Please advise
Old Feb 29, 2016 | 02:21 PM
Tootall's Avatar
just hit the search, put in LSA
https://www.performancetrucks.net/fo...ite-up-540743/
Old Feb 29, 2016 | 02:28 PM
Originally Posted by Tootall
already seen that thread, read several threads front to back multiple times. None of the threads answer my question. The op of that thread didnt use a stock tb, the used a ls7 Tb and an xlink...
Old Feb 29, 2016 | 02:56 PM
Y2KLimited's Avatar
here's an easy start to the question does your truck currently have the older style 3 bolt throttle body or the newer style 4 bolt......LSA is def the newer style
Old Feb 29, 2016 | 03:14 PM
I have a 2013 NNBS and it works on the LSA blower as it was the same as my CTS-V, but I'm going to say that an 06' probably does not work unless you have some adapter. Post a pic of your TB and I can tell you for sure.
Old Feb 29, 2016 | 03:16 PM
couldnt tell ya, its whatever came on the vehicle stock when i got it, so im assuming 3 bolt... have to look under the hood to verify
Old Feb 29, 2016 | 03:18 PM
your referring 3 bolt to 4 bolt adapter, correct?
Old Feb 29, 2016 | 03:25 PM
Yes sir! Something like this
Amazon.com: LS Throttle Body Adapter / LS3 4 Bolt Intake to LS1 3 Bolt TB DBW DBC 551511: Automotive Amazon.com: LS Throttle Body Adapter / LS3 4 Bolt Intake to LS1 3 Bolt TB DBW DBC 551511: Automotive
Old Feb 29, 2016 | 03:48 PM
And the electronics still work the same correct? Didnt know it was for dbw and dbc.... Thanks!
Glad i dont need that xlink. That was extra money unaccounted for... trying to get this done asap!!
Old Feb 29, 2016 | 04:17 PM
You should be good TB-wise, as the blower won't care if its wire or cable driven. Just use that adapter as it can convert from 3 to 4 or 4 to 3. You will have sensors in the case that you will have to wire up though if you want the readings, that stuff I'm not sure on. Glad to help ya on saving some greenbacks I do have a mod fun you can donate to.
