Will it make 500 rwhp?
Old Dec 28, 2007 | 06:28 PM
Crash Dummy's Avatar
Former Moderator :(
Originally Posted by Holty
was that a lq4 i'm assuming?
Yes stock block and crank with stock compression after market pistons and rods.
Old Dec 28, 2007 | 06:36 PM
stock48's Avatar
9 Second Truck Club
Originally Posted by old motorhead
So...a cam with more intake and exhaust duration and lift can make LESS power?
NO. As you decrease restriction(bigger cam, exhaughst, heads, etc) through the engine, boost goes down, and power goes up. Boost is just a mesure of restriction. Even with less boost you are getting more air through your engine, than someone with a stock cam and exhaughst.
Old Dec 28, 2007 | 06:46 PM
WJ MARK's Avatar
you'll probably make 485 whp. Just 1 hp. below me
j/k. I think you should be real close!
Old Dec 28, 2007 | 07:18 PM
old motorhead's Avatar
That's what I thought too, but it seems that the LPE cams make more with less.
Old Dec 28, 2007 | 08:40 PM
stock48's Avatar
9 Second Truck Club
I thiny you could use more exhaughst duration, but that cam's not bad. I would run it. You could try some 1.8 rockers on the exhaughst.
stock48's Avatar
9 Second Truck Club
I thiny you could use more exhaughst duration, but that cam's not bad. I would run it. You could try some 1.8 rockers if your springs will take it.
Old Dec 28, 2007 | 08:59 PM
MikeGyver's Avatar
Eggzawst
Old Dec 28, 2007 | 09:25 PM
Originally Posted by MikeGyver
Eggzawst
I'm not going to ask.....
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Silveradorst07
Dec 31, 2015 12:04 AM
JordanH
Aug 8, 2015 07:59 PM
black6spdz
Jul 16, 2015 01:32 AM
