Will Magnuson tune for a shiftkit?
Old Jul 24, 2007 | 02:52 PM
gimpygolden's Avatar
Default Will Magnuson tune for a shiftkit?
I've got my Radix on the way (should see it this week) and am now wondering what the tune will be like as far as line pressure goes. I have a Transgo HD2 and both 2nd and 4th sevoe's and told TByrne that when the order was placed.
Do you think they will still up the pressure or leave it stock? I right now have a Superchips tuner and run the pressure at stock or else part throttle shifts are to firm.
So do you guys think I'll be needing a tune?
Old Jul 24, 2007 | 02:56 PM
BlownChevy's Avatar
blownerator
25 Year Member
The trans calibration is done on a stock transmission. They will not make any changes for your shift kit.
Old Jul 24, 2007 | 03:01 PM
thanks, guess I'm gettin a tune
Old Jul 24, 2007 | 03:06 PM
but will changes to trans setting and e-fans enabled affect my Magnacharger warranty?
Old Jul 24, 2007 | 03:08 PM
BlownChevy's Avatar
blownerator
25 Year Member
pm sent.
Old Jul 24, 2007 | 03:14 PM
Wink
thanks blownchevy. I am going to see what it drives like.will hold on the tune it is a nice warranty
Old Jul 24, 2007 | 06:50 PM
Last Call's Avatar
TOTM: January 2007
Try using the powertrain warranty... It is a joke.
Unless they have changed the warranty provider since 2004.
Old Jul 24, 2007 | 08:41 PM
FastCrewCab4x4's Avatar
Isn't the warranty only valid if the radix is installed by a reputable/certified installer???? I thought home driveway installs are not coverd...I'm a far better mechanic than any shop around here and I don't think I qualify for the warranty cause I did it myself.. Is this correct???
Old Jul 24, 2007 | 08:46 PM
I was referring to the warranty on the Magnacharger not the optional powertrain warranty. I'm sure if something goes wrong with the kit they'll warranty it,won't they?
Old Jul 24, 2007 | 08:56 PM
I don't think you'll have a problem with the warranty on the blower it's self, they have to pass several checks before they even go out. I think failures are rare...
