The only thing I don't like about the OBD2 stuff is.
Doesn't hang down lower and is real easy to hit when getting in and out of the truck. (I've never had one I'm really just asking if anybody that has ran their truck that way.) |
(Post 5457566)
The OBD2 wideband only works on newer Can based ecms. Like 07-08 up Anything NNBS runs can-bus. Anything E67 or E38+. |
The OBS plug does not get in the way.
It's only sticks out maybe 1in further than stock and your legs will not curl under the dash and hit it. Ran my last truck for over a year and never once touch it and half time forget I even had it hooked up. https://cimg8.ibsrv.net/gimg/www.per...ad093d9f19.jpg |
So will that one display boost on the gauge too since it can read it through the OBD2? on a newer truck. Mine is 2014
Not that gauge. That is only an AFR/Lambda wideband gauge. I am not sure if they make a wideband/boost gauge with OBD2 support. Haven't looked at their site to see what new ones they offer with OBD2.
So what about Wiring for an Auto Meter gauge on a NBS I don't have the little data logger in the picture I was wanting to run it to the factory PCM EGR pins this is what I have heard would work. Just not sure what wires go to what pins. 2004 Silverado pcm I have already wired
White to Headlight switch to power Gauge lights. Red to switched 12V Blacks to good chassis Ground Need to know what pins for the Blue and the Brown wires. https://cimg5.ibsrv.net/gimg/www.per...3129d2d67d.jpg https://cimg7.ibsrv.net/gimg/www.per...353b96d564.jpg https://cimg0.ibsrv.net/gimg/www.per...363adc8f5c.jpg https://cimg1.ibsrv.net/gimg/www.per...0b7bbf9bb8.jpg |
If blue is 0-5v analog output it goes to the pin 55 egr location.
Originally Posted by Atomic
(Post 5457675)
Apologies on reviving an of dead thread! Simon |
Using a good ground is always best
(Post 5505551)
Ground it out it is. (Edit: signal output negative is what I'm talking about. ) Thanks Simon |
