wideband help!!!!
Old Sep 10, 2010 | 12:31 AM
gmc6.0's Avatar
Default wideband help!!!!
i recently installed autometer coablt wideband and i cant get it to work i follwed the directions to a T but it dosent display my afr. i turn the ignition on and the gauge lights up i wait awhile turn the truck on let it idle and i see the numbers go from begining to the end then it turns off no error codes or anything i already replaced the harness once any ideas?
Old Sep 10, 2010 | 12:54 PM
terravast4's Avatar
What about the 02 sensor?
Old Sep 13, 2010 | 11:16 PM
gmc6.0's Avatar
the 02 sensor is brand new and looks like it to....i called autometer and they said that i need a new power and ground source and not to hook it up to another gauge can anyone help who has installed a autometer wideband where do u hook your up to
Old Sep 14, 2010 | 07:22 AM
03_Denali's Avatar
I think Terra was referring to the correct 02 sensor to read wideband. It needs a Lambda Sensor. One should have came with the kit.
Old Sep 14, 2010 | 08:13 AM
bai78's Avatar
Mine is powered by the side panel fuse box. It is "t" into the correpsonding amp source.
Old Sep 17, 2010 | 04:43 PM
Bluecobra's Avatar
You need to run an independent power and ground to the gauge. I learned this the hard way trying to tie my AEM WB into the existing power and ground for the other gauges. The sensor needs a bit more power and doesn't like to share - so to speak.
Old Sep 18, 2010 | 12:36 AM
gmc6.0's Avatar
okay so how did you wire yours bluecobra, after contacting auto meter they said the power and ground cant be tied into the other gauges because it needs power to warm up the sensor...i tried hooking it to the battery same thing but the truck was off any other ideas...
Old Sep 18, 2010 | 01:17 AM
gmc6.0's Avatar
where does everyone draw their power for the wideband and where do you ground it at.....
Old Sep 18, 2010 | 01:23 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Is the entire gauge blank? Or do you see --- instead of numbers?
Old Sep 18, 2010 | 01:32 AM
gmc6.0's Avatar
yeah when i first turn on the ignition it shows -- then i wait for a mintue turn the truck on and it does the count down after that all the leds shows up and the numbers turn off then the whole gauge shuts off...
