Wide Band & Boost Gauges Recommendations
Old Jan 4, 2020 | 09:10 PM
therock's Avatar
Default Wide Band & Boost Gauges Recommendations
I Need Wide Band & Boost Gauge(s) Recommendations. Its been since 2005 that I have shopped. I'm setting up for another blower install and need to be able to log AFR & Boost on HPTuners (via MVP1).
Well I have PLX on another vehicle still going strong since 2005 but I go to their site and its horrible or I have dyslexia there, and the market and tech seems to have changed.
I don't want anything elaborate, even a single AFR/Boost gauge is OK as long as I can log. I read comments on ones with the boost sensor in the gauge don't read the lower numbers well.
Whats out there that's working well for you guys now?
Old Jan 4, 2020 | 09:29 PM
03sierraslt's Avatar
I use a AEM X series wideband and my other gauges are Autometer ultra Lite II.
Old Jan 4, 2020 | 10:22 PM
madmann26's Avatar
I use an AEM WB as well. No issues with it.
Old Jan 5, 2020 | 01:24 AM
therock's Avatar
Copy That guys. Thanks
Old Jan 5, 2020 | 12:48 PM
stroker87's Avatar
WB i had good luck with AEM and innovate, have no boost so cant help you there but innovate has a boost/WB combo gauge that a herd a lot of good about
Old Mar 7, 2020 | 10:12 PM
therock's Avatar
Thanks, I went AEM X-Series. These were for my 2013 Charger R/T. I put an E-Force blower on and keeping her sleeper like mounting them on the console. The shifter is a non-issue when in derive eh?
Nice the AFR is via OBD port. My dyno tuner used it for easy access to my wide band. I have PLX on my Truck since 2006 and didn't like what it takes to run their WB and boost these days.
03tahoe22
Feb 10, 2012 05:20 AM
r1les
Nov 7, 2008 06:53 PM
JakeBrakeIH
Nov 3, 2008 07:48 PM
