why no e85
Old Oct 18, 2009 | 06:24 PM
sdimer350's Avatar
look at this
https://ls1tech.com/forums/forced-in...05hp-corn.html
skolman91's Avatar
Originally Posted by terravast4
what does it require to run the e-85?
bigger than normal pump & injectors, and proper tuning.
Old Oct 18, 2009 | 06:45 PM
MikeGyver's Avatar
Originally Posted by skolman91
...and yes people say some mixes vary, but arent you depending on a steady current mix% now at the pump on your fixed tune.. either way i was on id be monitoring it if taking it to the edge on FI.. just my thoughts on it
Yes, but from what I read I thought that the difference in what's in the pump labeled E85 was outside my computer's ability to retard the timing safely.
Originally Posted by MNC5
...Comments like yours usually come from someone who doesn't have any experience running it.
You're right, I am guilty of spreading internet hear-say.
Old Oct 18, 2009 | 06:47 PM
skolman91's Avatar
Originally Posted by sdimer350
nice, for comparison sakes that car made 880@14lbs, and a recent dyno thread goin on right now on here made 853@18lbs, both 408s. i know theres prob more than a couple variables between the two but thought id throw it out there. also the truck was spraying meth to get his 853..
Old Oct 18, 2009 | 06:59 PM
skolman91's Avatar
dont think i fully understand what ur trying to say, just like in any tune when u get less octane than what its tuned for computer will take take timing away if knock is present. but the main good thing about e85 and its high octane is its resistance to knock.. as long as you pay attention to your tune(esp if your running it to the max) and know when they change blends(season change) i dont see how e85 could be anymore dangerous than a 93+meth tune.. just my2cents
Old Oct 18, 2009 | 07:06 PM
skolman91's Avatar
also if your really into self tunning you can buy the gm sensor that detects changes in the octane its self and adjusts the ecm accordingly(comes on the flexfuel stuff), so its seemless. only prob is its like $600 if i rem right.
Old Oct 18, 2009 | 07:26 PM
dirt track racer 81's Avatar
nice.. the fastest vehicle to run on e85 is less than a mile from my shop..i think it was 255mph
Old Oct 18, 2009 | 08:24 PM
MikeGyver's Avatar
You would need a FlexFuel ecm, I'm pretty darn sure.
Old Oct 18, 2009 | 08:44 PM
skolman91's Avatar
might be able to wire it in, but i wouldnt be surprised if you did need a new one. i was thinking of the fast system when i said that sorry..
Old Oct 18, 2009 | 09:07 PM
zittman's Avatar
OK, so you need bigger injectors and pump. I have 75lb(781cc) injectors and a Walbro 255 pump on my setup. I also have the Magnavolt to help out also. Does it take special injectors and pump for the E85? I know it would take some tuning, what else?
