Why does this vac/boost gauge do this?
Old Dec 24, 2013 | 06:07 PM
Random User's Avatar
Default Why does this vac/boost gauge do this?
It's an Auto Meter Sport Comp II that uses a MAP sensor. The line is hooked into the intake just behind the throttle body. The wiring harness is a plug-n-play deal so there's no wiring to screw up.
At idle it shows vacuum just like it should but if you blip the throttle it'll jump up to 5psi instantly. It's a centrifugal blower so there's no way it's making 5psi just off idle. I plumbed it to the brake booster hose with no change.
I ran a plain boost gauge to a port off the intake plumbing and it reads normally....no boost showing with a blip of the throttle.
I've never run a vac/boost gauge before...is this normal or is it screwed up?
Old Dec 24, 2013 | 06:16 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
What does the gauge read with KOEO?
Old Dec 24, 2013 | 06:59 PM
I found it. I had it wired to a switched connection like I always do....apparently it needs a connection that doesn't lose power during cranking. 'm on the hunt for that connection now.
Texas5.3_1251
Mar 5, 2016 08:10 PM
dantheman1540
Feb 24, 2016 09:56 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
zblee
Sep 17, 2015 07:58 AM
kmcn47
Sep 17, 2015 01:12 AM
