Who is running 10.0+ CR with boost???
Old Aug 13, 2012 | 06:29 PM
BlackGMC's Avatar
Resident Retard
Default Who is running 10.0+ CR with boost???
Just wondering who is running greater than 10.0 CR with boost these days???
Old Aug 13, 2012 | 06:43 PM
GTPSS's Avatar
I'm running 11.1 to 1 CR with an F1D procharger on a 416 stroker. Straight meth, 103lb injectors and upwards of 14lbs.
Currently broken due to oil pressure issue-NOT boost related.
Old Aug 13, 2012 | 07:03 PM
mhotrodscooter's Avatar
My buddy has a lq9 with stock 243's on 8-10lbs of boost with a mp112. Buddy's ls2 vette had 9-10lbs of boost.
Old Aug 13, 2012 | 07:06 PM
smokeshow's Avatar
Mod with training wheels
My old 6.0 was 10.1:1, was real strong on 10psi.
Old Aug 13, 2012 | 09:29 PM
kbracing96's Avatar
My new motor is about 10.6 but only running 2 days now. Gonna hit the dyno this weekend I hope.
Old Aug 13, 2012 | 09:50 PM
pewterliftedz's Avatar
you still running a LS1 KB?
Old Aug 13, 2012 | 10:00 PM
kbracing96's Avatar
No, I popped the head gasket on it and torched the head. New motor is stock ly6 6L short block with flat tops and JFR ported 317's. Triple 12 cam.
Old Aug 13, 2012 | 10:31 PM
good deal man, if you spot a LY6 short block for cheap out in Houston shoot me a PM..
Old Aug 14, 2012 | 12:56 PM
53bowtie's Avatar
Originally Posted by kbracing96
No, I poped the head gasket on it and torched the head. New motor is stock ly6 6L short block with flat tops and JFR ported 317's. Triple 12 cam.
Sounds real close to Stock48's setup. Should run real strong if thats the case. I may have to look into these JFR heads and Isky cam if I ever get a chance to turbo mine.
Old Aug 14, 2012 | 01:18 PM
nonnieselman's Avatar
his heads and cam are the ticket..
