who makes one of these for the Radix?
Old Aug 28, 2005 | 03:00 PM
moregrip's Avatar
what a rush!
Default who makes one of these for the Radix?
Old Aug 28, 2005 | 04:15 PM
ranwalk's Avatar
What does it do??
Old Aug 28, 2005 | 04:46 PM
moregrip's Avatar
what a rush!
Phenolic-A plastic molding component formed by the reaction of phenol and formaldehyde. It can be heavily reinforced or "filled" with glass fibers or other materials. Phenolics are known for their high impact strength, excellent wear characteristics, and dimensional stability over a wide temperature range
isolates heat
Old Aug 28, 2005 | 04:50 PM
moregrip's Avatar
what a rush!
****, I may go buy some maple or hickory and make my own
Old Aug 28, 2005 | 08:20 PM
Sounds interesting, but I am still trying to understand how this would benefit you. ???
Old Aug 29, 2005 | 12:29 AM
METAL MAN's Avatar
Originally Posted by moregrip
I make custom Phenolic spacers. Just send me a gasket and I'll make you whatever you want. I can do up to 1" thick.
Brett
Old Aug 29, 2005 | 11:16 AM
vanillagorilla's Avatar
Wood isolates heat better. Just do some research on carb spacers and you'll see. I'm not sure how it would do supporting a huffer though.
Old Aug 29, 2005 | 12:46 PM
dewmanshu's Avatar
Moderately Differentiated
I have researched this in the past, isn't the problem with the actual gasket of the radix...it's the same as stock so it's more of ring gasket...no clearance for anything else? Fits into a slot. It would have to be one large phenolic spacer with the rings cut on each side for the gaskets...like twice as many gaskets.
I'd like one just for the throttle body alone...great at isolating the heat.
Gadgetized
Aug 21, 2020 03:14 PM
lxcoupe
Aug 24, 2015 08:16 PM
Martin4_8
Aug 13, 2015 07:31 PM
therock
Jul 25, 2015 09:23 AM
sTNT971
Jul 16, 2015 12:39 PM
