Who has switched up their forced induction? procharger => TVS
Old Nov 20, 2010 | 12:41 PM
jetttstream's Avatar
Default Who has switched up their forced induction? procharger => TVS
Hey guys,
Just wondering who has gone from a procharger to a TVS setup (such as d-1sc to tvs2300)
OR
Has gone from TVS to Procharger.
I have seen a LOT of guys end up with a turbo setup as well, so just curious what was the *deciding* factors and why you did it.
Thanks in advance!
-Mike
Old Nov 20, 2010 | 02:44 PM
WJ MARK's Avatar
I started out with a P1 procharger and switched to a turbo. Deciding factor was I felt like I wasn't going to get much more out of the procharger. Turbos just work alot better up here than blowers do. Im sure If i was at sea level i would have been happier!
Old Nov 20, 2010 | 09:26 PM
joeyc125's Avatar
11 Second Truck Club
I had a tvs1900 on my 6L, was a great blower, ran it up to about 8.5 psi. Ran awesome, super reliable, quiet when not on the throttle, no maintenance required, instant power. The reason I switched to turbo is i wanted to run it up to 12-14 psi, and I just started out with the wrong blower for that much on that large of a motor. If I would have started out with a 2300, I am sure I would still have it. IMO, you can't get a better daily driver FI system then a tvs blower.
Old Nov 22, 2010 | 08:07 AM
Yeah see more or less the procharger (bypass) was noisy as hell when just cruising around and with the wife/kids in the truck is just seemed annoying.
From the looks of everything I've read if I want quiet and F/I the TVS2300 is the winner hands down.
Old Nov 22, 2010 | 01:28 PM
idahoblkss's Avatar
i dont know if you know but procharger has a new silent drive system that is super quit. dont know if you have looked into the vortech twin screw vts blower but i have a friend up here that owns a shop and sales all makes of blowers and and has had a tvs series blower and he said his vortech blower blew the tvs out of the water, from what he said .
Old Nov 23, 2010 | 09:08 AM
I personally don't mind the Procharger rattle and have yet to hear the new helical gear set.
BUT what I got sick of was the constant blowing of the bypass---however I did not have it recirculate or attempt to quiet it down. It was just annoying hearing the bypass sound change with every single change of the throttle.
Old Nov 23, 2010 | 11:00 PM
Rick_Vor's Avatar
I went from Procharger to turbo to try something different as much as to build a system that worked for my personal preferences. My biggest issue was the lack of low, low end boost and my personal dislike of stall converters for a daily driver. With a 5800 AWD Crew Cab, even the TBTC I installed just felt too loose in the hilly residential area I drive in everyday.
I've ran a few different Procharger setups. The ones with the bypass recirculated back into the intake filter were basically silent. With long tubes and comp springs, I couldn't even hear it.
Rick
Old Nov 24, 2010 | 07:53 AM
Interesting. They simply blew the air back into the tube with a filter that feeds the impellar?
Have any pics of these setups?
Old Nov 28, 2010 | 03:37 PM
idahoblkss's Avatar
yeah it just recycles the air back into the intake tube and you dont notice it unless your under alot of boost and let off, i think thats how the kits come stock.
