Who has a 31x12x3" intercooler mounted behind the bumper
Old Feb 9, 2013 | 06:02 PM
  #21
GMCtrk's Avatar
Nice work then.
Old Feb 9, 2013 | 06:11 PM
  #22
LsF-150's Avatar
Heres mine, the 4" CXR intecooler
Is that the 28" radiator? I want to run my cold side like that on my '06 but I don't have near that much room around the ends.
Old Feb 9, 2013 | 06:14 PM
  #23
03sierraslt's Avatar
Originally Posted by AndysC3
No pics. There was a plastic piece under the radiator held on with 3 push clips. It came with 2 brackets. I used the 2 outer holes and to bolt the bracket to the. To the intercooler. The pipes hold the top part in place.
So you don't have it mounted up top also?
Old Feb 9, 2013 | 06:27 PM
  #24
AndysC3's Avatar
Mine has the 34" radiator
And no the top side is not bolted to anything at the moment. It doesn't move thought
Old Feb 9, 2013 | 06:32 PM
  #25
Atomic's Avatar
I have a gauge for that
Mine is the 34" rad. I didnt have room either, but I made it happen anyway!
I have a bar going across mine to support the hood latch. If you cut that support you might want to consider something similar.
Old Feb 9, 2013 | 06:34 PM
  #26
LsF-150's Avatar
Hmm, Did you have to cut any part of the headlight mounting pastic? sorry for the sidetrack, Thanks
Old Feb 9, 2013 | 06:36 PM
  #27
Atomic's Avatar
Yea, basically all of it Even had to dremel the headlight bulb so I could turn it 90 degrees.
Old Feb 9, 2013 | 07:05 PM
  #28
smokeshow's Avatar
Mod with training wheels
Lol good to know. I plan on chopping out some of that **** too. You pulled out your condenser i assume?
Old Feb 9, 2013 | 07:08 PM
  #29
AndysC3's Avatar
Yea, a lot of the headlamp plastic had to come out. Here is my drivers side. I'm not sure what cooler this is but it was a pain to get around
Old Feb 9, 2013 | 07:09 PM
  #30
Atomic's Avatar
What size charge pipe do you have? I made 3.5" fit on mine
