Whipple 2.9 Low Boost?
Old Mar 30, 2020 | 08:16 AM
Jonblarc7's Avatar
Would it make a big difference if it was a turbo over a blower?
Old Mar 30, 2020 | 08:31 AM
03sierraslt's Avatar
It would work with a turbo also, naturally each type of power adder can benefit from a cam setup for the combo. But it would work fine. With a turbo if you have a small turbine they start getting pickier about cam choice due to back pressure.
Old Mar 30, 2020 | 01:39 PM
Last Call's Avatar
TOTM: January 2007
Something is wrong, you should see much more than 6-7 psi. At a min, I would think 10.
Are you measuring the boost with an external gauge or from your map sensor?
Old Mar 30, 2020 | 03:23 PM
gat0r's Avatar
5 Year Member
he specifically said it IS the 5.3 cam.
thanks & duh, on my part... i saw it & overlooked it b/c he said he had a 6.2
so i guess that is what i latched on to
Old Mar 30, 2020 | 10:44 PM
Jjblur's Avatar
Im at 500hp at 6100. 580ft lbs. At 3900 Tuner has 4 degrees pulled because I tow a heavy camper sometimes. Not because it was knocking. Said it had probably 50 to 60 more horse in it. I did adjust bypass valve and its a steady 7 lbs now. Boost is off intake and its mechanical
Old Mar 30, 2020 | 11:54 PM
Last Call's Avatar
TOTM: January 2007
I would confirm with MAP sensor readings and also check to ensure there is no belt slip.
Old Mar 31, 2020 | 07:32 AM
What does your mechanical boost gauge read at idle?
Old Mar 31, 2020 | 07:41 AM
madmann26's Avatar
You should be getting your reading from the lower tub.
There is an NPT fitting on each side of the lower tub that has a plug in it. Use that instead.
Old Mar 31, 2020 | 08:05 PM
Jjblur's Avatar
Yes thats where it is connected.
Old Mar 31, 2020 | 08:06 PM
Jjblur's Avatar
around 20 -22 vacuum
