Whipple 2.9 Low Boost?
It would work with a turbo also, naturally each type of power adder can benefit from a cam setup for the combo. But it would work fine. With a turbo if you have a small turbine they start getting pickier about cam choice due to back pressure.
Im at 500hp at 6100. 580ft lbs. At 3900 Tuner has 4 degrees pulled because I tow a heavy camper sometimes. Not because it was knocking. Said it had probably 50 to 60 more horse in it. I did adjust bypass valve and its a steady 7 lbs now. Boost is off intake and its mechanical
There is an NPT fitting on each side of the lower tub that has a plug in it. Use that instead.
