Whick stock based engine combo is best?
Old Jun 1, 2007 | 10:08 AM
TG02Z71's Avatar
Originally Posted by ChevyThunder17
Stock cam or a turbo specific cam? That's going to make a huge difference. STS used to have more data on their site regarding the 4.8, 5.3, and 6.0 outputs (dyno sheets @ 5 psi) but I can't find them. Methanol injection is going to keep you safe AND make more power for you. Stock compression is 9.4 on a 6.0 with 317 heads.
Would the Z06 cam work as far as a stock cam upgrade? I think that is what Parish has done with their pinks 5.3l engine??
What valve springs would work without blowing too much cash?
I don't want to get carried away being cheap but if I don't it WILL get out of hand fast.
Cash deep does not always translate into boost friendly. The combo of parts must be correct for my goal.
That is why I came to this site years ago, lots of great people with honest answers.
Old Jun 1, 2007 | 10:31 AM
ChevyThunder17's Avatar
Comp 918 springs are great bang for the buck (under $200), stock retainers (no need to Ti retainers). Z06 cam? I personally would go with something more turbo friendly but you could use that as it's better than stock. Upgraded pistons and rods (~$1000-$1300 depending on what you pick, plus the machining and balancing, and assembly if necessary), stock crank, fresh bearings, gaskets. The stock 317 heads flow the same as LS6/LS2 heads, just lower compression. You could use your 5.3L heads if you wanted, just get dished pistons, which many of them are.
Right now my setup is a factory bottom end LQ4, LS2 heads (I wanted high compression), Patriot dual springs (had them lying around in a box already) and Comp Cam of ridiculous proportions, Comp lifters (also lying around), stock everything else. I will know what it makes in a few weeks when I hit a dyno and finish tuning it.
Old Jun 1, 2007 | 10:40 AM
TG02Z71's Avatar
Good info. I would like a cam that is livable and easier to tune with. Remember I am not going for all out performance here. I would like some decent low end, no worse than it is now. Is the stock 6.0l cam any worse than the stock 5.3l cam?
How about a 2800rpm converter? Would that help off the line on a lower boost setting for daily driving?
Old Jun 1, 2007 | 10:47 AM
6.0 LQ9
207/196 int/exh @ 0.05" duration
0.479" / 0.467" int/exh lift
116 LSA
5.3 LM7
190/191 int/exh @ 0.05" duration
0.466" / 0.457" int/exh lift
114 LSA
The 6.0 does have some better specs on it, and a wider LSA. A converter will definitely help you off the line, but you need to have a transcooler and you will take a shot on your MPG (if that's an issue). A 2800 would work, some would say it's a bit of a low stall however I don't want to eat up tires by changing them from solid to gaseous form.
Old Jun 1, 2007 | 10:54 AM
TG02Z71's Avatar
6.0 LQ9
116 LSA
5.3 LM7
114 LSA
I have the stock trans cooler and a larger Hayden bar+plate style in the parts pile. A higher stall would be great if all I did was drag race and troll for ricers but that is not the main goal for me. Not to say it wouldn't be fun.
Old Jun 1, 2007 | 11:36 AM
kbracing96's Avatar
ChevyThunder17, you must not have read the thread that parish has going with their pinks car. Stock 5.3 with MP T-70 turbo, gained 100rwhp running 8 PSI with ONLY a 01 (the smaller of the 2 z06 cams) Z06 cam swap. The 02 Z06 cam has .025 more lift. They are running the LS6 yellow valve springs I believe.
TG02Z71, Here is the bottom draw budget, yet still strong boost motor I have planed for later this summer.
5.3 bored to 5.7 (my machine shop guy said he can get me a block and crank for $250)
SDPC Budget forged LS1 kit (comes with forged flattop pistons, rings, bearing, and ARP rod bolts for $600. Just forged piston for a 6L are $635)
317 6L heads with yellow LS6 springs ($60 from SDPC) Should keep the comp around 9.5 to 1
Vincie "Ultra Toque" cam ( almost identical to a 02 Z06 cam, just a bit more intake duration. I couldn't tell a difference when I swapped the two)
LQ9/LS2 rods (a bit beefer then the stock, and can be had pretty cheep).
ARP Head studs for a little more clamping force.
I think this setup should be good for around 700rwhp, with some 60lbs/hr injectors and a MP-70 at 15psi.
I like the idea of this motor combo, because it will get me the power and reliability I want and the parts are cheaper and easier to get. Also I drive my truck a lot, and wont have to feed the extra 30 c.i. of a 6L. Of course I WILL have to do something about the trany if i use this motor to it full potential
Old Jun 1, 2007 | 12:36 PM
TG02Z71's Avatar
You have a very solid plan, the 700rwhp is way beyond what I need. I would like about 600fwhp so I get about 475rwhp minimum.
Don't get me wrong, 700rwhp would be awesome but a little too crazy for me. I think my license would be gone after one weekend with that setup.
I like the idea of being able to run low boost and still have some grunt but not so much that if my wife had to drive it she'd get into a bad situation.
This is where all these question started in my head. Is there such a thing as the combo I am trying to work out on paper??
There seem to be good arguments for a 5.7l iron block and the 6.0l LQ4 lightly modded.
You guys have my ears!
Old Jun 1, 2007 | 12:54 PM
kbracing96's Avatar
HAha, what I meant is it will have the potential for 700rwhp, not that I'm gona running it there...much..lol . I will probable run it at the 7low/10high I run now and might bump it to 15 for the occasional trip to the track. One thing I would keep in mind about a lightly modded 6L is that you won't have the added protection of the stronger forged pistons.
You have about the same amount of machine work for a forged 5.7 or 6l either way, assuming you have to bore the 6L .030 over to clean it up, but the parts will cost more. Diamond is the only ones I have found that make an off the shelf forged piston for the 6L and a stock size rod. Plus used 6L cost more then 5.3. Man, I'm starting to sound like a sales man with an iron block 5.7 to sell,
Old Jun 1, 2007 | 01:03 PM
I'm looking at the post now. Does it make good power? Yes. It lost power up until 4800 RPM, after that it picks up. That is fine for a car, but I wouldn't give that up with a truck. The 5.3 stock cam run looks flat, I'm going with due to the lack of lift. On a 6.0, I would use something considerably bigger.
I never said it wasn't good, just not what I would personally pick.
Old Jun 1, 2007 | 01:30 PM
TG02Z71's Avatar
You guys both have good points. I would still like some decent low end without having to brake spool the thing from a stop. That just gets stupid on the street in traffic, nothing like flipping on the "Cop Magnet" neon sign.
With what you are saying about cost of a base 6.0l and parts being more expensive than maybe the 5.3l iron block bored to a 5.7l would be better budget for me.
I will go with forged pistons either way just for safety and longer life at the moderate boost levels I will be running.
Do I really need forged pistons with lower boost levels, say max of 10-12psi??
Probably not but I am now taking the better safe than sorry route for a build up.
Here is what I'm now thinking.
Forged 5.7l pistons.
Stock 5.3l, LS1 or Z06 cam?
ARP rod bolts and head studs
918 springs for safety
Do I need upgraded push rods?
If so what brand and length for either cam?
Could I use the stock 5.3l cam?
Are all the rockers the same?
What would make the most sense for my goals?
I must always keep in mind my truck weighs about 5400lbs, and always will.
