where to spray meth..help
Old Jan 14, 2006 | 06:07 PM
TwoFast's Avatar
Default where to spray meth..help
Where would the best place to spray the meth on my application...I've included pics...I was thinking of injecting it right at the elbow on the intake..
any suggestions?
does location #1 look best, or does #2 look better
Old Jan 15, 2006 | 08:48 AM
COLDZ71's Avatar
I agree number 1 looks best. More of a flat surface to tap and it sends it straight in.
Old Jan 15, 2006 | 08:59 AM
JimS's Avatar
I"m considering getting a meth injection kit. Have you made the plunge yet? Which one did you choose? What influenced you to buy one over the others? Thanks, Jim
Old Jan 15, 2006 | 09:57 AM
Wouldn't the best place to spray the meth be the inlet tube?That would be a lot easier.
Old Jan 15, 2006 | 10:25 AM
hemifever's Avatar
In a bend in the charge pipe is what I'm told allows a good flash. Bends are where there is the most turbulence. What I'm about to install isn't the most preferred by some but I like it. I just had a 1" CNC machine throttlebody spacer made and it's off getting a spray bar put in it. I'm having the bar drilled with holes to equal a 600ml jet. This will "fog" the meth in behind the tb which to me will allow a good atomization.
Old Jan 15, 2006 | 05:35 PM
2500HD6.0's Avatar
I sent you an e-mail to day of where I put mine in
Old Jan 15, 2006 | 05:46 PM
jcfreak's Avatar
any suggestions?
According to the Snow Meth instructions, the best place to spray is in front of the throttle blade somewhere between it and the maf. I drilled and taped my throttle body on the left side about 10 oclock right infront of the throttle blade.
Avsfan's Avatar
[IMG][/IMG] This is where I had mine installed.
Old Jan 15, 2006 | 06:01 PM
TwoFast's Avatar
I've been told that the meth isn't good on the rotors/internals of my blower. I thought that meth can corrode the inside of my blower after a while.
Is that true? thats what I'm wanting to spray after the blower....
Old Jan 15, 2006 | 06:08 PM
jcfreak's Avatar
Thats a new one on me. I have never heard that before. When you spray it, mix it 50/50 with water. It will last longer. That stuff aint cheap.
