Where To Spray The Meth
Old Jul 20, 2005 | 02:12 PM
stssilverado's Avatar
Default Where To Spray The Meth
Can anyone tell me where the IAT sensor is on an '04 5.3? I'm installing a methanol kit and am being told 2 stories. 1. Place the meth nozzle before the MAF. 2. place the nozzle after the MAF before the TB(cause the IAT is in theTB?). If the IAT is IN the TB, then option 2 is the answer.
Here's my problem. If you spray methanol (a flammable liquid) onto the live wires of the MAF, won't it F' up the signals. Don't those wires produce heat?
Old Jul 20, 2005 | 02:35 PM
JERRY2500's Avatar
14 Second Truck Club
I know on my truck the IAT sensor is with the MAF. I added an IAT sensor and put it between the TB and Injector. Read This
Old Jul 20, 2005 | 08:02 PM
camcojb's Avatar
Both SMC and Snow Performance tell you to inject it as close to the entrance of the throttle body as you can. That would be AFTER the MAF and IAT on my Ford, and should be on your Chevy. I wouldn't spray before the MAF, too easy to throw off the airflow readings.
Jody
Old Jul 20, 2005 | 11:09 PM
XLR8NSS's Avatar
Adkoonerstrator
The IAT is integrated into our MAF sensors on the GM's although some guys have relocated to get better temperature readings with there blower setups. The MAP is on the back of the intake manifold also so there is no way to spray after that.
How is the MAP sensor setup on the Fords? I don't understand how it could get a good reading if it's not on the intake manifold which would be after your TB.
Old Jul 20, 2005 | 11:52 PM
camcojb's Avatar
Sorry! I meant MAF, there is no MAP on the Lightnings. That's from my speed density days!
Jody
Old Jul 21, 2005 | 08:32 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
You want in before your IAT or the PCM will be pulling timing unnecessarily. I moved my IAT sensor to my intake tube an inch past the meth nozzle (which is 3 inchs from my tb). It cost about $20 and took 5 minutes.
Old Jul 21, 2005 | 09:25 AM
camcojb's Avatar
That's a good idea. The Lightnings have two IAT's and the second one is after the intercooler in the lower intake runner. That's the one that adds/subtracts timing.
Jody
Old Oct 23, 2005 | 07:13 PM
greentahoe's Avatar
So spraying before the MAF is alright?? I have a larger 625 nozzle after the MAF and I want to put a smaller 325 nozzle before the MAF. I was thinking that the meth would cause some screwy sensor probs.
Old Oct 23, 2005 | 07:22 PM
quicksilverado's Avatar
I would not spray befpre the maf sensor.
Old Oct 24, 2005 | 09:53 AM
Wilde Racing's Avatar
How do I change this text
I've alwas been told not to spray before the maf.
