Where to get oil pumps?
Just bought a twin rear mount turbo kit, and it does not have the pumps with it. Needing to know where to buy them, and if someone has an installation guide from their STS kit that they can share with me that would be GREAT!! I didn't get to see the kit hooked up on the truck, so I don't really know where to locate everything. It has an Air-to-Water intercooler w/ ice box. Just need some instructions so that I can compare, and get a general idea.
Thanks,
Austin
Thanks,
Austin
You can get oil return pumps from STS or a STS dealer. Check the sponsors to the right------------->>>>>>>>>>>>>>>>
Here are a couple of other sources that might work.
Mocal pump:
Mocal Differential Cooler Pump
Reverso GP_301 pump:
Reverso GP-301 Oil Gear Pump
Maybe try LS1Tech or STS for a manual.
Good luck with the kit sounds like it will be a lot of fun once you get it up and running.
Mocal pump:
I got mine from an STS dealer that upgraded his customers kit to the high flow version..
Also, I noticed you said "pumps", maybe it was a typo, but you only need one pump even with the twin kit. Did your kit some with the wiring harness that runs the pump at a lower speed at low engine speeds? Mine just runs full blast all of the time and it is pretty damn loud.
Thanks guys. Well I called STS and they said I can't get just the pump from them, they also were the ones that said I would need a pump for each turbo because I am planning on over 600 rwhp. But I did find a company on LS1Tech that I will be ordering the pump from. Hopefully it won't be to long before I give ya'll he results! I think it's gonna be fun!
Black one, the red one will be sold this Fri. So everything I had planned for the red one will go to the black one, plus twins! Good lookin truck by the way! Looks awesome.
STS doesn't make a twin kit for the trucks. If it was sold to you as an STS kit, it's been heavily modified. If it was just sold as a twin rear mount I'm not sure the STS instructions will help.
STS won't sell their oil system outside of a kit.
Damn, so ol' Red is gone huh? lol. Oh well, im interested to see how the black truck turns out. Should be pretty damn quick!
I know STS doesn't make a twin setup. It is Green Thunder's old kit. I only want the instructions so that I have an idea of where they mount things like the oil pump, how they have the wiring ran, how they have lines ran, stuff like that. This kit came without oil pump and turbos. So ordering the pump tomorrow, and bought the turbos Rick@Synergy was selling.
