whats a good crank case ventalation for a turbo ?
Old Jan 28, 2008 | 12:35 AM
stock48's Avatar
9 Second Truck Club
Originally Posted by mike06tork
i think it had only 16 degree of timing at wot and my tuner was logging while i was test driving it and he said no knock it ok but i dont knok ,will the forged motor will be alot harder to blow it up will it take 11-15 psi and hold on
Detination will kill any engine, a forged engine will just take more before it dies. You cannot allways trust the factory knock sensors. I have pulled more than one LS1 appart and found the knock sensors surrounded by water, and corrosion. Those grommets leak water in, and it has no way out. The 5.3 out of my truck was really bad, would det just driving down the road in od. My 6.0 had signs of it to, so I replaced the sensors, cleaned out the cavity ,and siliconed the groments in.
Old Jan 28, 2008 | 05:46 AM
parish8's Avatar
single digit dreamer
what kind of fuel are you running with that 11.6psi? meth?
if your just running pump gas and no meth 11psi is too much boost.
Old Jan 28, 2008 | 07:15 AM
Slowhawk's Avatar
LS1Tech Sponsor
Sounds like you should work on what caused the piston failure first.I know on my truck at 7lbs it only like 14 degree's of timing on pump because of the weight of the truck.You don't lose 2 pistons for no reason.
Old Jan 28, 2008 | 11:33 AM
kbracing96's Avatar
YA, I run 12 lbs, spraying meth and 16* of timing. I wouldn't think of running that with out the meth on pump gas.
Old Jan 28, 2008 | 02:45 PM
vanillagorilla's Avatar
Yikes, your engine sounds worse than mine.
What were your AFR's while your tuner was tuning it? If he didn't have a wideband or anyway to tell your AFR's then get yourself a new tuner.
16* timing, no knock and 11psi on pump only is kind of hard to believe. Can you get ahold of the log files and post them up?
Old Jan 29, 2008 | 06:14 AM
Wilde Racing's Avatar
How do I change this text
what was your a/f ratio? Like other have said 16 is a lot with-out meth. I can't hit that with meth.....
Old Jan 29, 2008 | 04:19 PM
mike06tork's Avatar
yep i was running with out meth i got tired my truck was just sitting in my porch for two weeks and my wastegate 6# spring didnt get here quik so i just took it to tune it here at xsessive motorsports i had the snow boost cooler but i didnt have any meth so i took my chances and so it was bad *** it felt real strong i wouldnt control it at 35 or 65mph so on my way back home i did a 65 run and its when it broke my eng. had only 10k miles so now im going to forged it with some probe -13.5cc pistons at around 8.8-9.1 comprssion and some scat I beam rods and some Hellfire rings and bore out my 5.3 to a 5.7L. what do you all think about this would it take 11-15psi or maybee even 18 psi what do you all think what would you all suggest on my botton end so it can hold on to the turbo>..?????????????
Old Jan 29, 2008 | 04:59 PM
parish8's Avatar
with rods and pistons it will take a ton of power BUT you still need good fuel or meth to go over 9psi or so. the lower compresion might give you 10psi or so.
Old Jan 29, 2008 | 05:10 PM
thunder550's Avatar
High on diesel fumes
I'm about 9.4:1 and without meth I start to get knock at about 7 psi or so on 91 octane.
Old Jan 29, 2008 | 06:12 PM
MikeGyver's Avatar
With what kind of timing?
