what wasteegate / bov is used in this truck
Originally Posted by Lord Aries
That is the Livernois kit on an EXT, and that sound is Compresser surge from NOT having a BOV... I know this because thats exactly what my truck sounded like after installing the Livernois, now i have a Forge Dual Piston BOV that is pretty loud. I am going to change the BOV for the new motor because the Dual Piston is too slow on the opening and i still get some surge so, i plan to go to a full atmo vent BOV on my new set up when done... Should be PHAT nasty loud! hehe
i thought it was just the bov fluttering open and closed. if i get that noise even with a bov does that mean the bov is too small or just not adjusted right? how do you size a bov?
Originally Posted by parish8
i stand corected. that is the exact same sound i hear on my truck and most turbo cars i have seen but your right, the livernois kit doesn't even have a bov.
P.S. Just for the reccord I was not trying to correct anybody just put in my .02. I am still learning every day about these Turbo thingys... LoL
[/QUOTE]
that's what it's all about bro. learning. no one knows it all but you can come close with all the great help you get on here.
[/QUOTE]that's what it's all about bro. learning. no one knows it all but you can come close with all the great help you get on here.
it is good to post up especialy if there is some bad info being spread around. now that i know that noise isn't just the bov fluttering i will try and adjust it out. i am running twin 38mm bov's so hopefully i can adjust it to blow off nice and smooth
guess i am used to other boards where you get yer azz chewed for stating an opinion. LoL
When i started my Turbo project last year i did not know much at all, I installed everything myself on a truck it was not design for, it took six weekends but i got it done. Then i turned around and swaped a transmission and learned some more... All i know is I am ready to ditch my career in Computer Tech support to becaome a total gear head in a shop! I am starting my Welding class in August, oh yeah!
hehe sorry, back to topic... LoL
Parish, the BOV should be set so it just bearly closes with idle vac on it. Then when you step on the gas and the vac goes away, it will stay shut. Mine is a cheap Bosch bypass off a Volvo, and is not adjustable and is open at idle, so I have to have a filter on it, so dirt doesnt get sucked in, but when the vac drops off, it closes and the boost pressure holds it closed until you let off it and the vac sucks it open and it go's pusssshhhhh. If it go's woop, woop, then its too tight and needs to be loosened so it go's pusssshhhhh. HTH,
You learn something new everyday. Looks like I'll be adjusting mine soon.
The funny thing is: No where in TiAL's instructions does it say how to or that you even need to adjust the damned thing.
What do you mean a four tire burnout in a fourbanger isn't natural? It is with 450hp from 25 psi and 10,000 rpm racing cams.
