what times are you running with your turbo setup? (1/8th, 1/4 mile)
Old Apr 14, 2011 | 07:06 PM
  #51
Toomnymods's Avatar
im in same boat as you, truck holds till it builds boost then it blows thru the staging beacon..
Old Apr 14, 2011 | 07:13 PM
  #52
tarinitup's Avatar
9 Second Truck Club
It will hold more boost with slicks at the track and same procedure.
Old Apr 14, 2011 | 07:16 PM
  #53
black04's Avatar
How are you doing the shuffle?
Rev it in neutral and push down the brake, you'll feel the brake go down a little more, put it into 3rd and floor it.
Old Apr 15, 2011 | 12:31 AM
  #54
TXjeepTJ's Avatar
I did the same procedure, but instead of putting it into 3rd I just put it into drive. I read mixed reviews about putting it 3rd and drive, maybe I should give it a try in 3rd
trarinitup your probably right, I tried it just on a regular street w/ the tires cold
Old Apr 15, 2011 | 08:41 AM
  #55
JFOLM's Avatar
Some members & sponsors suggest to race in 3rd. It applies more clutch area I believe.
Old Apr 15, 2011 | 10:12 AM
  #56
black04's Avatar
Ah yeah forgot you were 2wd. With 4wd I can floor it all day and the boost will keep rising and rising lol.
Old Apr 15, 2011 | 10:42 AM
  #57
N20GMC's Avatar
Along with doing that try stomping the parking brake after you stage. I used to do it in my turbo buick. And it helped with keeping the car from rolling the beams. But i'm 6'2 and have long arms so that might not work for everyone.
Old Apr 15, 2011 | 04:56 PM
  #58
joeyc125's Avatar
11 Second Truck Club
First, see if you have a check valve in your brake booster line right at the booster. My crew cab had that stupid canister thing with no check valve, so any boost would blow into the vacuum booster and work against you. I got a check valve from an 02 truck and it was night and day, held 100X better. I am not sure when they switched from the check valve to the little canister thing, but my 00 has the valve, 05 has the canister.
Old Apr 16, 2011 | 06:35 PM
  #59
TXjeepTJ's Avatar
I don't think I have the check valve, here is a picture
can I get the check valve at a parts store or do I need to go to dealership?
Old Apr 16, 2011 | 09:10 PM
  #60
Toomnymods's Avatar
maybe this checkvalve will work for me as well, where excactly do u install it? cause my brakes work fine till the motor isnt making vacuum anymore and starts seeing boost..
what is this hydroboost thing everyone mentions?
