What size turbo for rear mount?
Old Sep 17, 2012 | 08:29 AM
tqcraver00's Avatar
Default What size turbo for rear mount?
5.3L longtubes 210/218 116lsa .551 .551 + 1.8 rockers .584 .584
I'm going to build my own turbo kit seeing as I have a pipe bender and can weld tubes like a champ haha
I want 4-5psi keeping stock heads and bottom end. I would be more than happy with 100 rwhp/tq
I plan on having the truck dyno tuned after install
turbo?
TiAL 38mm wastegate
The Mocal 12v Oil Pump
Blitz Blowoff valve
Old Sep 17, 2012 | 09:08 AM
nonnieselman's Avatar
My buddy is running a Magnum 76mm Q trim on his 5.3 Rear mount with a baby cam. 14psi and it ran a mid-high 11.
Old Sep 17, 2012 | 09:59 AM
ZO6Ted's Avatar
I really liked my GT67 at 8-9 lbs. but I bet a little 60 would be sufficient for 5lbs. Experts will chime in.
Old Sep 17, 2012 | 10:17 AM
I ran the Garrett 60mm that come with the STS kit and it was ok. 6psi should be 125 extra RWHP.. roughly.
Old Sep 17, 2012 | 11:28 AM
tqcraver00's Avatar
I want a turbo that will spool rapidly with the stock stall
what about something smaller than the GT60?
Seeing as it is rear mount and only 5ish psi could I get by without an inter cooler for a while?
Old Sep 17, 2012 | 11:47 AM
Ferocity02's Avatar
I'd say something in the 60-70 range if you're only looking for +100hp.
Old Sep 17, 2012 | 11:55 AM
60mm would the the smallest id run.. not gonna be able to spin it high either.. i think i was shifting at the 5500rpm range.
And no intercooler can be done,, but not suggested.
i rode around for two days with no intercooler. saw 165-175 and said no more.. went and redid the piping and put the W/A ic on..
Your gonna loose what little power you pickup with the high IATs.
Old Sep 17, 2012 | 03:03 PM
black00chev's Avatar
Slowest turbo build ever!
Even a small air to air intercooler will be better then nothing.
As far as turbo size, I would look for something in the 62-67mm range. That way at the low boost you plan on running, you will be working in the efficiency range of the turbo. Keep the exhaust A/R around .86-.96 so that it will spool decently and not completely choke out up top.
Also, keep the exhaust pipe from the headers to the turbo around 2.5" so that you keep the exhaust velocity up to help with spool times as well. And maybe consider wrapping the headers to help keep the heat in as well.
Old Sep 17, 2012 | 05:28 PM
tqcraver00's Avatar
will my stock fuel injectors and 15,000 mile new gm fuel pump be fine for low boost with a dyno tune?
Old Sep 17, 2012 | 06:08 PM
I'm guessing by your screen name that you have a 2000 year truck? If so then I wouldnt even try to use the stock pump/injectors. I would look in to a Walbro 255 intank fuel pump and some 42# injectors. Better safe then sorry when it comes to fueling.
