What size pulley for MP112?
Old Sep 20, 2009 | 10:09 PM
richierich14608's Avatar
Anyone else have any thoughts about their being a nose drive that you cannot change the pulley on?
Old Sep 21, 2009 | 12:49 AM
Dewey's Avatar
Originally Posted by terravast4
It is different based on the mods you have on your motor, so a pulley change isn't really a apples to apples comparison.
someone correct me if i'm wrong, but the only time that's true is if you have an underdrive or overdrive crank pulley
Old Sep 21, 2009 | 10:35 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Here ya go. http://cgi.ebay.com/ebaymotors/3-0-Q...Q5fAccessories
Old Sep 21, 2009 | 04:56 PM
Doobie's Avatar
I'm using a 3.3" pulley on my 5.3L and seeing 8 psi with mods in sig.
(stock heads)
Old Sep 21, 2009 | 06:18 PM
So no one knows for a fact how or why the nose drives would be different on a Joe Gibbs edition MP112 vs. buying one directly from magnacharger?
Old Sep 21, 2009 | 07:08 PM
The nose drives are different. Pulleyboys makes both styles. You can contact them about whatever pulley size you want. I posted a link in my previous post. Hope this helps you.
Old Oct 10, 2009 | 12:44 AM
03tahoe22's Avatar
How about posting a picture to let us see what yours looks like?
Old Oct 12, 2009 | 07:51 PM
BlownHD's Avatar
There are a ton of factors that will affect how many lbs of boost a person is making. intake, TB, Cam, Heads, compression ratio, exhaust will all affect the psi.
When you are measuring psi you are measuring how much pressure is built up in the intake manifold of your motor. Pulleying down and leaving everything else stock will increase psi and increase power, now add a nice cam and a free flowing exhaust and your psi will decrease, but your power will increase even more because you have removed a restriction.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
murderedSS
Sep 22, 2015 03:53 AM
Justin87gn
Sep 10, 2015 12:06 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
