What Oil do you guys use ???
Old Feb 20, 2013 | 09:58 AM
  #31
Atomic's Avatar
I have a gauge for that
I think I have used 10w30 and 20w50. Zinc protects against high temperatures longer...so basically the oil will take longer to break down, especially in an abusive enviroment like a turbo. All of the racing oils dont have detergents though, so the oil needs to be changed more often.
Old Feb 20, 2013 | 10:57 AM
  #32
TX Tahoe Z71's Avatar
Man, Rotella is way cheaper than Amsoil 0w-30 signature ($120 for 12 quarts)... I may consider switching to T5 after I run through this Amsoil box
What are your oil change intervals?
Old Feb 20, 2013 | 12:28 PM
  #33
TURBHOE's Avatar
i buy the rotella 15w40 (live in florida) by the gallon is 14.99 and for a 2.5 gallon is $29.
tractor supply always has a good deal on it. 3000 miles change interval, according to everything i read that is the break down point of it. up to 3000 its great oil, after that it goes south quick.
Old Feb 20, 2013 | 04:15 PM
  #34
Beatdown Z's Avatar
Laid Back
I always buy Brad Penn off Ebay.
Old Feb 24, 2013 | 07:24 AM
  #35
05_GMC's Avatar
I've got 126k on my truck, always ran 5w-30 with the cam nitrous setup. But going boost ima go with a castrol 10w-40 conventional.
Old Feb 24, 2013 | 01:05 PM
  #36
MGMC's Avatar
12 Second Club
20-50 here
Old Feb 25, 2013 | 02:44 AM
  #37
07NNBSVMAX's Avatar
I run Royal Purple 5w30. I'm also still N/A. I've always had great luck with RP, it's all I've ran for years.
Old Feb 25, 2013 | 08:06 AM
  #38
TURBHOE's Avatar
I use to run royal purple 5w30. But when I went turbo I noticed at 3-3500 miles when I would change it, it came out like water. Very thin and nasty looking. It seems like the turbo put way to much of a beating on it. Switched to rotella and motor sounded better and the oil looked better at change time.
Old Feb 26, 2013 | 06:17 AM
  #39
Beatdown Z's Avatar
Laid Back
My buddy used my garage to change out the royal purple in his truck. i went ahead and pulled the drain plug for him. Same thing as turbohoe said, **** came out like water. I think it's part of the reason you can "gain power" with royal purple.
Basically giving up protection for you engine to gain a couple ponies. I'll never run it...
Old Mar 11, 2013 | 11:14 AM
  #40
Vortec350ss's Avatar
Is the thicker oil to help with cooling of the turbo, or because of the increased heat associated with making more power?
