This is what happens when a 102mm turbo lets loose.
Old Oct 14, 2013 | 03:19 PM
Gadgetized's Avatar
Default This is what happens when a 102mm turbo lets loose.
This isn't truck related but I thought some people would like the pics. My girlfriends father has a pulling tractor with a compound turbo setup. The air goes in 2 102mm turbos, and then into a single 108mm turbo. Well at the Enderle pull off in September this year one of the 102's let loose. It split the wheel in half, and threw debris out the front and into the other turbo.
His tractor is called Desperado and it starts pulling at 32 seconds.
NTPA GRAND NATIONAL OPEN SUPER STOCK AT THE 2013 ENDERLE PULLOFF URBANA, OHIO - YouTube
Old Oct 14, 2013 | 04:53 PM
cammed00's Avatar
Love watching tractor pulls
Old Oct 14, 2013 | 05:40 PM
TIM Z's Avatar
11 sec. Truck Mod
X2 love tractor pulls !
Holy sheet that's one hell of a turbo setup , what's he see 70-80 psi ?
I bet you and him get along good huh ? Lol
Old Oct 14, 2013 | 07:26 PM
black00chev's Avatar
Slowest turbo build ever!
"sssssssssssssSSSSSSSSSSSSSSSSSSSSSS...... POP...... awwwwwwwwww"
Old Oct 14, 2013 | 07:44 PM
Atomic's Avatar
I have a gauge for that
and car drag racers think they make big power
Old Oct 14, 2013 | 07:48 PM
Gadgetized's Avatar
The 102's make about 50 PSI. The bigger one is compounded to 110ish.
Old Oct 14, 2013 | 08:29 PM
Gadgetized's Avatar
He will dyno next years setup. Im interested to see the numbers it puts out.
Old Oct 14, 2013 | 08:32 PM
Atomic's Avatar
Probably 3000 or so with a lot more torque if I had to guess. Good luck finding a dyno to handle that.
Old Oct 14, 2013 | 08:48 PM
Gadgetized's Avatar
His boss actually has one that will hadle it.
Old Oct 14, 2013 | 08:49 PM
SSpeeDEMONSS's Avatar
100-200psi is normal for high level compound setups. should be well over 3000. 2000+ has been done with a single on a 5.9 based cummins.
oops, i was talking diesel engines, not alky.
Garrett
