What is going to hold me back?
Old Aug 15, 2012 | 01:01 AM
stock48's Avatar
9 Second Truck Club
It will spool quick but power is likely going to flat line by 5K tops. For 5~600HP and 5~5200rpm shift it will work ok just don't expect 800HP, and 6500RPM out of it.
Old Aug 15, 2012 | 01:05 AM
smokeshow's Avatar
Mod with training wheels
Originally Posted by Ferocity02
Would a 1.15 AR housing help much? That is an option on these, but I already have the 0.96 AR version on my shelf. Might just run it as is to see how I like it.
So will the small turbine wheel help it spool up quickly then?
That depends on if the .96 isn't cutting it... Small turbines generally spool faster.
Old Aug 15, 2012 | 02:18 AM
Ferocity02's Avatar
Thanks for the info guys!
One more thing. My truck has a T56 6-speed, not an auto. Would a smaller turbine lend itself better to a manual than an auto in terms of spool up time?
Old Aug 15, 2012 | 03:42 AM
smokeshow's Avatar
Yeah definitely.
Old Aug 15, 2012 | 08:28 AM
Johnmaster's Avatar
MASS seller approved
Was considering a 160 t-stat myself and then read a pretty convincing article against it (I believe on LS1 tech). Pretty sure it had something to do with oil viscosity and bearing life, can't remember.
Old Aug 15, 2012 | 08:31 AM
lglowe's Avatar
After feeling the gains from a 75mm turbine over a 65 and 68 wheel ill never go back to something that small. Its easier to reach you power goals too. Gonna make more power per # of boost. I would think it would be easier on the motor too. A lot less pressure and can run a little more timing safely
Old Aug 15, 2012 | 09:03 AM
nonnieselman's Avatar
I agree,, dont go cheap.
Get a good size turbine and that thing will have a wicked top end.
Do you have a 2 Step??
Old Aug 15, 2012 | 11:08 AM
Ferocity02's Avatar
Already went cheap But certainly can't hurt to plan out the next turbo
Am I correct in thinking that I'm going to max out the Walbro 255 quickly? Assuming a bsfc 0.65lb/hp-hr and flow rate 60gal/hr at 13.5V, that's about 560 hp.
Old Aug 15, 2012 | 11:22 AM
bud8fan's Avatar
get away from that .96 AR to a bigger .112 or larger...the results are un real...
Old Aug 15, 2012 | 12:11 PM
lglowe's Avatar
You'll be fine with one 255 for now. Just add in another when you feel like you need another
