What is going to hold me back?
That depends on if the .96 isn't cutting it... Small turbines generally spool faster.
Was considering a 160 t-stat myself and then read a pretty convincing article against it (I believe on LS1 tech). Pretty sure it had something to do with oil viscosity and bearing life, can't remember.
After feeling the gains from a 75mm turbine over a 65 and 68 wheel ill never go back to something that small. Its easier to reach you power goals too. Gonna make more power per # of boost. I would think it would be easier on the motor too. A lot less pressure and can run a little more timing safely
But certainly can't hurt to plan out the next turbo
Am I correct in thinking that I'm going to max out the Walbro 255 quickly? Assuming a bsfc 0.65lb/hp-hr and flow rate 60gal/hr at 13.5V, that's about 560 hp.
