What gauges should I run?
Old Oct 14, 2014 | 02:12 PM
Wiggs757's Avatar
Registered User
Default What gauges should I run?
hey guys, this is going to be my first forced induction set up and I'm wondering what gauges I should run? Highly doubt I'll go over 8 psi. Running true duals if that makes a difference. My friend told me to run boost, a/f, and pyrometer.
Old Oct 14, 2014 | 03:26 PM
BlackGMC's Avatar
Resident Retard
fuel pressure
Old Oct 14, 2014 | 03:44 PM
Wiggs757's Avatar
Registered User
Originally Posted by BlackGMC
fuel pressure
Why is the fuel pressure important?
Old Oct 14, 2014 | 03:49 PM
BigKID's Avatar
'Cause if you don't have it, you engine goes boom. With FI and the extra demands on the fuel system, it is good to know everything is in check with it. It is especially helpful if tuning yourself as AFR doesn't always tell you everything you need to know.
Old Oct 14, 2014 | 04:00 PM
black6spdz's Avatar
I run Boost, fuel pressure and a scan gauge to monitor knock and trans temp
Old Oct 14, 2014 | 04:01 PM
Wiggs757's Avatar
Registered User
Makes sense, so basically I would be able to know if my fuel pump wasn't keeping up with my injectors? Does the fuel pressure just put a sensor on the fuel rail?
Old Oct 14, 2014 | 04:02 PM
Wiggs757's Avatar
Registered User
Not sure I know what a scan gauge is?
Edit: I googled it, but is it really necessary? My truck already has a trans temp gauge
Old Oct 14, 2014 | 04:03 PM
Wiggs757's Avatar
Registered User
I'm guessing the pyrometer isn't really necessary?
Old Oct 14, 2014 | 04:38 PM
GRRR65GTO's Avatar
I havent seen many gas guys run a pyrometer
I only have boost and A/F but fuel pressure is good to have too
Old Oct 14, 2014 | 05:32 PM
GMCtrk's Avatar
The only gauge you NEED is a wideband.
I've been boosted for 2 years with just a wideband. Granted, I have a boost controller that can display boost but I don't look at it while driving.
To me, no gauge is going to save you from blowing your motor. The damage occurs before you can react to the gauge, especially with how fast stuff happens while in boost.
