What gauges to get for my whipple Denali
Old Apr 18, 2008 | 09:05 PM
Bromaguire's Avatar
Default What gauges to get for my whipple Denali
I bought the Socal disel gauge mount and I am going to put a boost gauge in one spot but what should I get for my other spot. With my Turbo M3 I run a water temp, Oil temp, and Oil Pressure gauge. Would one of those be recomended for my Denali with the whipple charger on it?
Old Apr 18, 2008 | 09:09 PM
fuel pressure is important as is air/fuel ratio.
OLD BULL's Avatar
A wide band O2 gauge. I personally like the AME gauge.
Old Apr 18, 2008 | 09:17 PM
supersub's Avatar
Wb Fp!
Old Apr 18, 2008 | 09:21 PM
nightrunner's Avatar
Mr. Obvious
since you have a denali you already have all the normal necessary gauges(speedo, tach, oil press., volts, fuel level, water temp) and the added trans temp gauge in the stock cluster.
i would suggest getting a boost gauge, fuel press. gauge and a wideband AFR gauge. you could probably get by without the wideband AFR if you dont do your own tuning as even if you know your AFR, you cant change it
Old Apr 18, 2008 | 09:24 PM
Bromaguire's Avatar
Anyone no what gauges will lite up blue. I have blue LED lights in all my A/C vents so I kind what a gauge that will look good and match them some.
Old Apr 18, 2008 | 09:27 PM
Mr. Obvious
autometer cobalt
Old Apr 18, 2008 | 09:33 PM
supersub's Avatar
autometer c2 also
Old Apr 18, 2008 | 09:45 PM
Bromaguire's Avatar
Originally Posted by nightrunner
autometer cobalt
Originally Posted by supersub
autometer c2 also
I just bought the Socal Disel gauge pod will these fit into that ?
Old Apr 18, 2008 | 09:57 PM
Bromaguire's Avatar
By the way guys thanks for all the super fast repsonses!
