what do yall think of this cam (vortech 4.8l)
Old Nov 3, 2010 | 10:03 PM
11 Second Club
Default what do yall think of this cam (vortech 4.8l)
its a lunati cam... going in an ecsb step side.. with 4.10's and a tb stall and a vortec v2
•Advertised Duration (Int/Exh): 287/298
•Duration @ .050 (Int/Exh): 222/230
•Gross Valve Lift (Int/Exh): .534/.544
•LSA/ICL: 114/110
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 2500-6000
Old Nov 3, 2010 | 11:16 PM
swift700's Avatar
I'm no expert but I'd go with a little more LSA and lift, and a little less duration. With that cam you won't get the maximum off the line with your 4.8, unless you have a higher stall along with your procharger. Otherwise, it's not a bad cam for the application. It will make good top end power.
OHsixLS3
Dec 27, 2016 09:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
lycominghunter
Jul 29, 2015 04:24 PM
lxcoupe
Jul 27, 2015 08:19 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
