What boost cam to go with 07 5.3 Avalanche 4x4
Old Feb 28, 2025 | 11:29 PM
Raptor_WS6's Avatar
Default What boost cam to go with 07 5.3 Avalanche 4x4
I need to do the DOD delete to my avalanche now. So might aswell get the cam I am gonna need.
i plan to put a positive displacement blower on it eventually so want a good cam for that.
the thing is 1 don’t want to do a higher stall converter. i am keeping the stock one in there. I was gonna do the truck Norris cam before I decided to do the blower so now I’m back to square 1.
Many input is appreciated thx
Old Mar 1, 2025 | 08:34 AM
MikeGyver's Avatar
My opinion is that if you think that cam would require a looser converter, it might be great for a PD blower. With a stock converter, slightly softer low rpm power might help keep your tires from lighting up off the line. In the same situation with a higher stall converter, you might have to do a lot of pedal work to keep the tires from spinning on launch.
If you are RWD. If you are AWD, this might not apply at all.
Old Mar 1, 2025 | 10:23 AM
TrevorH's Avatar
I’m running a 214/222 .578 lift on a 114+4 from Cam Motion that PatG spec’d for me. This is in a RCSB Z71 with stock converter and PD blower. It works very well with the stock converter. According to my Dragy, I’m running 7.4 in the eighth with 1.7 60ft times on regular street tires. Only slightly noticeable idle.
Old Mar 1, 2025 | 01:17 PM
FFDP's Avatar
Any of the stage 1 or stage 2 camshaft from whomever like BTR or Texas speed, they should all be around that 212/218 size or smaller. Those all work with stock converter and will always work with boost.
Old Mar 1, 2025 | 04:51 PM
68Formula's Avatar
SDPC LS6 Powermax 204/222 112+2 or SummitRacing SUM-8719R1 209/217 112+1.
Old Mar 2, 2025 | 08:22 AM
smokinlmm's Avatar
I ran the btr stage 2 with a stock converter and it was a nice daily driver.
Old Sep 16, 2025 | 07:12 PM
Fullpower's Avatar
Texas Speed 212/218 .550" works real well in a 4.8L under Magnuson @ 11 PSI
I'd recommend it for a 5.3
1FSTZ71
Mar 19, 2014 01:36 PM
Iconoclast
Nov 14, 2013 06:57 PM
Krab
Feb 12, 2013 11:12 PM
l_kusler
Apr 9, 2012 12:59 AM
07silveradoss
Oct 13, 2009 03:59 PM
