What am I missing for Radix install?
The one on the fuel rail only has one connection point, that is for returnless. If you have a return system, then you need the block that you mount the factory FPR into and also has 2 fuel line connections.
I used a heat exchanger from a TBSS, not sure how it compares to the CTS-V h/e, but it is pretty darn big, looks to be at least the size of the caddy h/e. I fabbed my own brackets to hang it mostly behind the grille, but some extends down behind the bumper. I can get some pics of how I did it if you like.
And am I going to need pigtail connectors to run the 42's?
I'll be running a 3.3" pulley (I'm thinking 8 psi), so since I have the 42# injectors, I might as well use them, right?
Got almost everything I need and then some from BLOWN 364! Picked up:
Kenne Bell boost a pump
intake tube
wiring kit
belts
hoses, clamps, etc
decals and belt diagram
return style fuel manifold
front fuel line connector
intercooler reservoir mounting bracket
Just need the CTS-V intercooler and coolant crossover now, but the intercooler is backordered until next week
intake tube
wiring kit
belts
hoses, clamps, etc
Mossyoakglock
Aug 28, 2015 12:49 PM
zblee
Aug 3, 2015 03:45 AM
therock
Jul 25, 2015 09:23 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
